Good to read you got it worked out with some effort and dedicated labor. As we have all learned, when something just doesn't make sense... question it.
(like your tech telling you to toss the furnace). Keep vigilant on the CO tests until your 100 % comfortable with the readings on an average. (get the furnace cycling for longer durations) Good job![]()
Yes, that's the one, I believe that will be a pretty close match to what you have. I think it's a great idea to have a plan rather than just replacing the existing pump. As far as a heat transfer fluid goes I would recommend Dowtherm.
Pics of the circulation pump.
Bumping this thread because i need some more advice.
I came home from my first week at my new job, and discovered the flange gasket dripping my heater water in the basement floor. I probably lost about 20 oz of water while I was out at work today.
I assume that if I unbolt this pump at the flange, The impeller stays with the pump just like an automotive application?
I realize I will have to drain the system to replace this gasket.
There is also a incoming water line that has a gate valve on it so I can refill the system after it is dry.
Is this a standard gasket readily available at home supply houses like Lowes or Home Depot? Any tips on doing this job would be greatly appreciated, as always
That boiler needs a proper teardown and cleaning, heat exchanger sections need to be cleaned, burners need to be cleaned. A combustion test after that will determine if there are any other problems but I doubt there will be.
The gate valve between the boiler and the relief valve needs to go away immediately and a pipe from the outlet of the relief to within 3" of the floor needs to be installed, as a tech I would not touch that boiler until that valve was removed.
It looks like I am due to replace the bearing/impeller housing anyway. Which will cover all of the problems I had. (considering this part was seized when I first started this process and I freed it up) I knew it was gonna be short lived after that.
I did however go ahead and do some things that needed done, prior to ordering these new parts.
My question is, why is there a pop off valve on my supply line after the shutoff valve and before the unit? Here it is pictured,
Ayuh,.... I'll try,.... Toss that whole pump, 'n replace it with a cartridge pump like a Grondsfo(sp) 3 speed, or taco 007,...
It'll come with new gaskets,...
While yer at it, replace the flanges with These,...
No drainin' next time the pump needs service,...
That's the pressure reducin' valve that limits the system pressure to 'bout 12 psi goin' into it,....
Yer's just happens to be a combination valve, with the pop-off, most don't,...
More than one pop-off valve won't hurt a thing,...
My system has 3 in it,...
One on the original oil boiler, 'n I put 2 on my homemade outdoor wood boiler,....
None open before 30 psi, 'n both will open within' a psi or so of each other,...
Interesting, at first I thought it was a combo backflow/fill valve but from what I can find it's a combo fill/pressure relief, never seen one before. If the fill portion is functioning properly you should be able to leave your incoming water supply valve open and the system should fill to around 12-14 psi cold. If it's not functioning properly then I would replace it with a new fill valve(also known as a pressure reducing valve) and I would add a dual check back flow as well if there isn't one already.
I would consider replacing the entire circulator with a sealed style(taco 007 or similar depending on what you have now) before putting much money into the old style b&g. If you keep what you have replace the pump coupler while you have it apart, they tend to fail when you least expect it.
) The link you gave me points me to a large variety of flanges, could you look at this pic and direct me to the particular flange you would select?
As you know.... the distance between the TACO and B&G flanges will be different. Every time at work I made a Taco/B&G pump change out that is what I found out at least.
Just get your TACO pump in if you choose to buy one, then take measurements and see what size ****** lengths you will need ....to close in or open up...the existing flange to flange distance, to make the TACO flanges fit....BEFORE you take the BG off line and disconnect it . Good luckJMO
Nope,.... 'fraid I can't,.... Yer there, ya gotta measure, 'n see what'll fit,....
Lotsa diameters, options, 'n lengths,....
Thanks guys, I think I am gonna rebuild the B&G pump as we have been happy with the performance of it and the motor/mount/cradle was replaced 7 years ago. This pump style has been on this home for the last 40 years so it seems to be well suited for the job
The cost is about $150 for parts either way and rebuilding the current pump makes it easier on me and should avoid additional fitment hassle.
I do believe I would like to eliminate that extra pop off valve on the incoming water supply line, just to rid the system of any old failure points as I am sure that is the same piece that has been on the system since wayyyyy before 2000 when this new boiler was installed.
Would removing this be OK?
Good move on keeping the B&G, they are a standard out here in the boiler heating industry for as long as I have been around.... I am no tech either.
As to your wanting to get rid of the blue text valve...... Someone correct me if I am wrong ....but I think that is a old pressure regulating valve. It basically keeps the incoming water pressure stable for the boiler.
I went back to the pics and I saw an old expansion tank suspended from the floor joists. That may help explain why you have a pressure regulating valve in your city supply water line to the boiler. They put PRV's in to help stabilize the city water pressure in a set range of pressure to the expansion tanks .....of which probably as you say, was for an old boiler now removed.....
I am NOT a boiler/heating tech, but I would say if you are confident in adding water by hand, do so. Just remember that if you leave town for a week in the heating season, someone needs to check on the boiler water. If that is not possible, then a boiler service company would be a good thing maybe, to get them inspect your system and get an automatic feed water system installed. JMO and Good luck![]()
A comment on the pop-off valve -
My boiler has a similar combination fill/safety valve, and when you pull up the lever on top it is in fast-fill mode. However, the catch is that when it finally fills up and fully pressurizes, the pop-off valve activates and you start dumping water out the copper tube going down. Its really surprising how much water dumps out that tube before you realize the boiler is full and you need to take it out of fast-fill mode.
Bruce
