How many welding tables?
crooklyn
Prince George, BC
Ok so how many welding tables do you have and why?
I have a 4' x 3' table and now my father inlaw want to build another table 6' x 32".
The shop is only 560sqft
I think we would be better off building pipe stands and horses for when welding longer pieces.
This is just a hobby shop not welding full time more fun for his retirement and for me to work on my quad and toys
Ilikeike
Northern Ca.
I like two,sometimes I'll have a project spread out on one,and need another for something else.
Two small ones at home and two large ones in the shop at work.
kaymccampbell
Upstate New York
I have two. A fixed bench 3x8 in the corner for small stuff. It is also my main auto and metal shop workbench. Then I have the lift which makes a nice adjustable table.
matt_i
SE Michigan
What's the purpose of 32" x 72"? that seems really long and skinny...unless the 36 x 48 is crowded with stuff.
It all depends what kind of work you are doing. For my needs I have a single bench and tig weld on it. For big stuff I take it outside and usually stick weld on it.
I can see the utility of a table with a grid of tapped holes or a platen & accessories. But currently don't have room for those tools nor the work to fully utilize them.
4 FN 27
Minnesnowta
I have 3. One is a bench 48 x 96 for more sit down type smaller part jobs. This one has Peg Board so I can hang all my clamps and whatnot. A shelf built in on top for tubing and a shelf built across the bottom for squaring blocks and anything else I may need to build a "frame".
Also have a 60 x 72 Blanchard Ground 5/8 thick Table for bigger projects and frame type work.
And I built a 48 x 96 Low table with a 1/4 thick top with 3/8 dia holes on 3 inch centers for fixture type work. I need to add the legs to this one so I can raise and lower it as needed. I have them designed just need to make them yet.
I am still in the process of moving in to the new garage behind the house.
sberry
Brethren, Michigan
I have 2, one with a vise. The benches themselves are not much but the location is everything.
4 FN 27
Minnesnowta
4 FN 27 and sberry
You guys have huge sweet shops!!
Thanks for the input much appreciated all
Thank you. A 40 year dream come true after a lot of sweat and blood...your shop isn't too shabby either. Well thought out and well planned!!! Nice work!!!
astroracer
Mid_Michigan
I have three dedicated welding tables. One small 12" diameter table, and two others on casters that were repurposed from trash picked bathroom vanities. They roll where ever they are needed. :)
Here is the bigger one under a wagon frame I was building.
Not good pics of either but you can tell what I did. This is the smaller one. it is used mostly for layout and grinding but has seen it's share of welding.
Mark
nadogail
Coronado, CA
My tables a 24" square with a vise bolted on it, and a half sheet of Hardy Backer thrown over two sawhorses.
58Yeoman
Central IL
I've got one that is about 24" square that I got from work, and never use. It's also got a pipe vise bolted onto it.
sberry
Brethren, Michigan
My shop is super custom to the nature of the work. Not super sophisticated but very ergonomic, as close to perect as a pair of vise grips can be. There is a bit of extra walking in some cases but very little congestion. In summer and nice weather I work out of side door and it's a pull in for welding. I can drive in to work area or reach outside.
The walk way to any area is straight, past wash sink, past tool box and along side island benches.
metalmagpie
Seattle
I am a big fan of one welding table with outboard supports as needed for larger pieces. Big welding tables are great if you have the floor space but I never have and never will. Tables have the problem too that they fill up with clutter.
metalmagpie
Conniptor
South Jersey
I have zero! I use the garage floor for welding, but I don't weld too much or often. If I had more space I would like one though.
bobcatdan
Kaukauna,WI
I could say I have four area to weld. The main bench where the welder sits next to. It's nice for a quick bench project to just lay it on the bench and go to it. I normally just leave the ground clamped right to the bench. My other bench has a steel top and I have welded a lot stuff on it. My roll around lift cart has proved a handy welding spot. Although I haven't used it for welding, I can't rule out never welding in my pedestal mounted vise.
AJO
2 benches, 5 ft. x 14 ft.x 1/4 for layout and weld and 30" x 48" x 1/2 for straight welding.:D
zkling
Quantity:1
Reason: Lack of space
Type: Cast iron
If I had more space I'd have a cast iron t-slot or the like jig table and a mild steel table for rough work that can take a beating.
That's your GARAGE? At your house? :shocking: Dimensions?
K13
St. Albert, AB Canada
This is another option from Miller costs a bit more but the top is 3/8 plate steel instead of stamped.
http://www.zoro.com/miller-electric...1rGIQUvzvSp_2RLtoI0dzxoCASTw_wcB&gclsrc=aw.ds
I don't have one but I borrowed one for a week from a friend and was happy with it.
Brian
I looked at the Miller one when I bought mine and the added cost and weight made the Stronghand one a better option for me when I had to take it down and pack it away everytime I used it. I also wasn't always working on a flat surface so the tilting table was another huge plus over the Miller one. For the money the Stronghand table is a very good table. I was very pleasantly surprised at how robust it actually is. I honestly feel it is probably the best bang for the buck I have ever spent on a tool.
sberry
Brethren, Michigan
I don't know how good a bench they are but not obscenely priced for the convenience of gathering up the materials and some paint. It would cost that much with other company logo.
sberry
Brethren, Michigan
I have made several carts, traded some around. A salvage dryer cabinet and a plate top would be the ultimate in cheap but for 400 would consider a HF44 box with a plate top added.
I am coveting one to replace my old wreck but I don't got to use it as a bench. If it was a space issue its something I would consider, instead of hangers for all the tools toss them in box.
