mooman
Without breaking the bank, what's a good recomendation for a good hand impact driver for the weekend warrior?
Yup. I find it;s usually faster and easier to just weld a nut on the stuck screw and use an air gun.
I suppose it depends on your application.
the Craftsman impact looks like it's 1/2" drive. Is that too big, or should I be looking for a 3/8" drive for general purpose use?
I have a spare Cman version that I can let go of
I have had my other Cman one for several years and it works very well
one note I will make is that the 'bits' are not lifetime from Cman
bob
Where I see the hand impact used a lot are the two screws that sometimes are used on brake rotors. Using an air impact I think carries a big risk of damaging the screw. With the hand impact the same instant you have the rotating force your have the whack of the hammer seating the bit. Seems to work great, so I wouldn't change without a good reason.
Some of the hand impacts are one direction only, so look at what you buy.
