PCL Digital Tire Inflator
Fedwrench
Valley of the sun
Yes, it's what we use at work. They have a newer version with a much shorter hose. Great inflator, durable, accurate, ez to read, and long battery life.
james.work.90
Can you set it and forget it? IE set for pressure and walk away while it fills?
Sent from my SM-N920V using Tapatalk
Dave455
Sussex, England
I have the non digital version. It's about 20 years old and hasn't had problems!
I doubt you will be able to say the same for the digital version in 20 years!
engineer2
Chicago burbs
No. That type of equipment exists, but is generally powered by a wall outlet and very expensive.
Where is yours made?
PCL is made in England.
Digital doesn't have any moving parts to wear out and dropping it won't affect accuracy.
fordnut85
I use the same one in the shop and love it. Accurate and seems to flow more than some of the others I have used.
Dave455
Sussex, England
I agree with the theory, but it doesn't work that way in practice!
I think I have 3 dead digital multimeters lying around, wheras my old japanese analogue, not to mention my Dad's Avo, are still working!
My old digital watch is long dead, but the Timex I had as a kid still works!
Don't even start me on digital Verniers...!
Sure, I agree that mechanical ones will lose their accuracy when dropped, witness the accuracy of petrol station ones, but at least they still work to a degree!
Most of this digital stuff dies over time whether you drop it or not!
At least PCL still make most of their stuff in the U.K.
engineer2
Chicago burbs
It can go both ways. Digital stuff will suffer from exposure to moisture and components can fail on occasion. Mechanical gauges can suffer from corrosion, dropping, and mechanical wear. It all depends on how much money you want to spend. Low end digital and mechanical gauges are essentially throw-away items. Higher end gauges are often more durable and repairable.
