Tracs
I came across a 60G Sanborn air compressor at princess auto in the clearance section that was complete minus the electrical motor for less than 1/3 of the regular price so I snatched it up.
The tank say it is 3.7 RHP. The motor is also labeled 3.7. I have been reading about inflated HP ratings on compressors. The compressor instructions state the unit draws 15A. Would 15A make 3.7HP? If it did would that be running or peak?
My friend gave me a Emerson 230V 3450RPM 2.5 HP running, 4.2 peak HP pump motor. It looks like it will bolt up and will only need a 1/2" bore pulley instead of 5/8" to complete it.
Do you think that the compressor will perform satisfactory with the above mentioned pump motor? What will the disadvantages of a slightly less powerful motor? Low PSI? Low CFM?
Here is the compressor in full form.
http://www.princessauto.com/en/deta...ricated-belt-drive-air-compressor/A-p8348955e
