Are no scratch lug nut impact sockets worth buying?
impactsocket
Are no scratch lug nut impact sockets worth buying? I will use my electric 1/2" impact wrench on the no scratch lug nut impact sockets. Will the plastic sleeves come apart?
How is the Astro Pneumatic 5PC NO SCRATCH LUG NUT SET?
spin_prod_38065101
Rubiman14
SE MI
I bought these Astro sockets off the SO truck a few months ago, to use with my new Jeep wheels. Only had a chance to use them a few times now but so far they're holding up. I'm using a 90 ft/lb torque stick and then a torque wrench to finish, though.
LXCam
I've yet to find a custom set of wheels that they fit. The coating normally kills it which is why I bought them in the first place. Go figure :(
I
impactsocket
Will using an electric impact wrench on these no scratch lug nut impact sockets tear up the plastic inserts inside the sockets? Can you buy replacement outer sleeves?
Rubiman14
SE MI
I was wondering how many wheels these would work on. They barely fit my beadlocks. Sounds like I got lucky! For the price, I don't really care if they ever fit another wheel.
Astro_Pneumatic_Tools
South El Monte
OP,
They have a warranty, even though these plastic guards get chewed up.
You drop me a line and you get at least free replacement sleeves or inserts.
____________
Chris
Product Manager
image.php
K-Dog
Millersville Maryland
I have those sockets.
I can't say for sure if they work or not, but I have never marrd a wheel while using them.
I would rather use them and be safe than use a metal socket and take the risk.
CJM8515
Used those sockets, busted several sets. Not sure why but they didnt hold up and I wasnt using air, older snap on cordless impact.
If you are worried about the finish of the wheels wrap painters blue tape on the socket. Insides that touches the lug-no idea wtf you could do.
liam.fenemore
I've had the CP ones that are identical for a couple years. They get used every so often and I use them on an air impact. The only thing that's gone wrong for me was the sleeves will fall of, but I just glued them back on. Pretty good value I'd say.
rayh91
SoCal
Thought about getting some, didn't want to worry about getting them warrantied though. So I passed.
I usually switch to chrome sockets with a light touch of the trigger if I'm worried about scratching the wheels.
kctyphoon
Jersey/Staten Island
I have a flip set like tekton I use with my cars.. Haven't scratched my wheels or lugs yet. I'm not a mechanic, but my feeling is that if your beating the sides of the lugs with an impact, and they don't scratch, I'm not sure you need any "protective" plastic.. If your putting on/off expensive rims or anything on a new car, I'd "hope" people would take the extra tenth of a second to line up the socket instead of just slapping it on. If your willing to buy the protective sockets, you would probably do that anyway.. I might be wrong on this, but I've never scratched up my rims or lugs and I've have a bunch of aftermarkets..
shockwave
Marietta,ga
I have had the Cornwell set off a few years now it has been great broke a few here and there but also doubles as thin wall sockets for custom wheels and lifetime warranty
The only wheels I have had issues with is Mercedes amg requires slightly deeper 17mm that cost a pretty penny from hazet too
joecon
I have that set from about 10 years ago and they held up well
the plastic sleeves brake but it takes a while. If you deal with fancy
wheels they are worth it. also had a socket with a aluminum insert
for the lug bolts on Porsches.
I
impactsocket
How do the Chicago Pneumatic no scratch lug nut impact sockets compare to the Astro Pneumatic? Chicago Pneumatic are lower price but are they lower quality?
The CP set comes with 17mm, 19mm, 21mm.
I
impactsocket
liam.fenemore, do you see noticeable wear on the inside of your Chicago Pneumatic no scratch lug nut impact sockets?
abvw
Toronto, Canada
There aren't many 21mm impact sockets that can clear the stock Nissan/Infiniti rims, I think they purposely designed this so you're required to hand tight the wheels. No issues with other brands.
Most other small lug bore aftermarket rims are often paired with spline lug nuts with a key so socket diameter/clearance are not much of a concern anymore.
I
impactsocket
How is Chicago Pneumatic's customer service in case the plastic sleeve/inserts break?
I
impactsocket
Chicago Pneumatic SS413WP 1/2" Drive 3 Piece Metric Deep Wheel ProtectorImpact Socket Set is only $20.86 on amazon.com
Does the low price = low quality???
http://www.amazon.com/Chicago-Pneumatic-SS413WP-Metric-ProtectorImpact/dp/B001JJBN4I
Chicago Pneumatic is even lower price than Harbor Freight. HF gives you SAE also but I don't need SAE.
Harbor Freight 1/2 in. Drive SAE & Metric Lug Nut Impact Sockets 7 Pc - Pittsburgh Automotive $34.99
greyjasper51
essex, uk
i have a set, not broken one yet, they are SO ones but i agree i have found that with the plastic covers on they are the same thickness as a std socket, however something ive not got round to yet, but between christmas and new year i will do it...
remove all the sleeves and plasti dip the outside of the sockets so they have a thin rubber like coating that protects against the wheel but isnt that thick.
if anyone has done this already and has feedback that would be great, also save changing sleeves just peel off the old plasti dip and apply new
I
impactsocket
Are the black oxide finish thin wall impact sockets as thin as the shinny colored thin wall sockets?
JonDick13926
Sidney, Ohio
I've always felt a little apprehensive about these. In part because I've never seen anyone use them, which I think says a lot. I have always wondered about the Koken ultra thin wall impact sockets though. I'm thinking those would be a better idea, or at least that's where I'd rather put MY money.
http://frankstools.com/koexthwaimso.html
I
impactsocket
Here is a video of the Harbor Freight no scratch lug nut impact sockets in use:
Harbor Freight no scratch lug nut impact socket set overview video:
dutchgray
Dorset. England.
That is where my money would go if I needed these sockets, but since all my vehicles have steel wheels on I don't need more than a standard socket.
94EG8
We have a set at work, more often than not you have to take the sleeves off because they wont fit, then they start falling off all the time because they've been on and off so many times.
pacemade
Alaska
Use a hub centric ring, tightening by hand the way the instructions specify on the box and use a little grease on the socket and your rims will come out just fine. Always re torque your new wheels 50-150 miles after putting them on.
Greg85mcss
Frederick MD
The same thing with newer legacy 19mm. Other than those specific situations they work pretty good
JettaGetUpandGo
Pewaukee, WI
I have the Sunex version with no issues and really like them. Previously I used a chrome Craftsman socket with heat shrink tubing around it. A standard impact socket didn't fit. I broke the lugs free with a breaker bar and tightened them with a torque wrench so minimal stress on the socket from an impact. It really only used to spin the lugs off and back on.
6-Speed
I have the Harbor Freight set pictured above in post #22. I have only used one of the sockets so far but the Delrin sleeve on half of them have started to split. The nice polished finish probably won't hold up. Other than that they are nice tools and you can easily remove the sleeve exposing a thin wall socket. I needed another 17mm lug nut socket so I just purchased a Sunex thin wall impact socket without the fancy finish or protective sleeve.
ImStricken06
Within Range
i have seen the plastic get chewed up. i simply cover a basic impact socket with painters tape, and it works fine. just replace the tape as needed.
I
impactsocket
UPDATE: I purchased the Chicago Pneumatic no scratch lug nut impact sockets and they are excellent. The plastic insert falls out but you can glue it down.
