FordTruckWench
I'm designing a temporary foundation for an 8x15 storage shed. The shed needs to be at a specific elevation: About 42 inches floor to ground at the downhill (long) side, and 32 inches at the uphill side.
I've decided on a floor of tongue and groove Douglas fir 2x6's laid the long way. They'll be supported by 4x6 floor joists spaced approximately every 2 feet. The ground to joist elevation is thus 25 to 35 inches.
I've been going in circles trying to find the best way to support the joists. I've considered having two 15' 4x beams each supported by four to five 4x4 posts sitting on concrete pier blocks. The posts would be diagonally braced either to the next post or to the beams. But I'm not happy with this design.
Another idea is to omit the 15' beams. A pair of posts and pier blocks would support each joist. The materials for this may actually cost less than the other design, but I'd have to align and level two rows of 9 pier blocks.
Q) Is there some other simple design to consider?
Note: Eventually the shed will get a masonry foundation. This will require that the temporary support posts do not bear around the perimeter. It would be nice if the pier and beam design can readily be modified to do this.
Q) The only pier blocks I've found locally have a square of 2x6 lumber nailed on top in a depression in the concrete. This does not seem appropriate for a wet (i.e. outdoor) area. How/where can I find a better design? Somewhere I saw piers with embedded metal straps to attach the 4x4 post.
