not sure if this is the right section, if not, please move to which ever section is appropriate.
i'm fixing some sprinkler plumbing in the yard and needed to join half of PVC union joint to a 1" PVC sch40 pipe. This is the supply side and so I shut off the valve from the street, but there was still a constant trickle of water; I'm guessing the old valve from the street doesn't shut completely.
I know about those "test ball plugs" that you can insert and inflate to plug the pipe and then pull out. But I couldn't find any store locally that had it, tried both Home Depot and Lowes and then contacted a local plumber supply shop... they didn't have anything that would fit a 1" pipe. Being sort of in a bind, I just decided to cement the PVC wet. As I pushed the two pieces together after priming and spreading the cement, I could see some of the PVC cement wash out with the water that was coming through. Did the usual 1/4 turn and held it until it was solid while the water was still trickling out. It seems to hold, and I let it set for 3 hours and just pressure tested it and it seems to be holding. I'm monitoring it and hoping it is good. But the fact that I saw some of the cement run out with the water makes me wonder if the joint might be weak and I'm just asking for future problems or not? Would hate to have to dig all this plumbing out again (it sits 12" below grade in very hard clay-like soil).
Anyway, if it continues to hold pressure, should I be concerned at all? Also, any "hidden techniques" for this type of situation should I need to redo it or encounter some thing like this again?
Thanks for any thoughts...
