akpolaris
I have a shop with 16' walls, T1-11 siding, Tyvec wrap, 2 X 6 framing, R-19 craft backed insulation and 6 mil vapor barrier. I am finding a a lot of condensation on the inside of the Tyvec. The inside of the building is heated with radiant heat kept about 50 - 60 degrees. The walls are sheathed with 7/16" OSB. On the south side wall prior to sheathing the last couple of sheets of OSB I noticed that the insulation was wet at the top. I stripped off the vapor barrier and pulled the fiber glass down to let it dry and look for any possible;e leaks. I did not find any leaks but this condensation does not seem right. Any ideas or other things to look at?
