maverick302
I got this as my first drill press a few weeks ago. I had been looking around for something a little more decent but found this 5 mins away for next to nothing, so I figured it couldn't hurt to get my feet wet with. It was (is) rough... has quite a few hacked repairs. When I got it, the column rack (broken) was held on at the bottom by hose clamps, the wiring was exposed in the junction box, things were loose...
It has a newer looking 1/2hp dayton motor, but clearly the wrong pulley. Either the quill spring assembly is the wrong size or the depth stop mount is, because they interfere - the PO rounded out the hole on the spring holder. Since the quill spring is broken, I'll try to find one that fits correctly.
Runout seems ok without using DI, and everything seems to run fairly smooth otherwise. My question here is: Should I throw a new belt on it and just run it as is until I feel the need for something nicer? Or do you think it is worth putting some time and money into to fix the quirks?
