Need a replacement starter capacitor for a grinder..
larryq
I have an older bench grinder with a cylindrical starter capacitor. I want to redo the wiring, including the capacitor, but have no idea what to get as a replacement, what specs I need. The existing capacitor has no specs on it.
The grinder itself is 1/3 HP, 3.5 amps and 115v. The existing cap is about 3.5" long and has a 1.5" diameter.
WRT to connecting to the two posts on the replacement, does it matter which wire goes to which post?
Any suggestions on what to get from, say, McMaster-Carr?:
http://www.mcmaster.com/#ac-electric-motor-capacitors/=10ca1rw
mattblast
Bridgewater, NJ
I buy motor capacitors from Home Depot. They have all the most common sizes available and ship free to your local store. Cheaper than eBay or Amazon. Takes 3 or 4 days before they are ready for pickup.
http://m.homedepot.com/s/capacitor
If old one is soldered on I suggest to crimp terminals to wires to allow for easy change out in the future.
Be sure to match voltage and capacity (mfd) to original. If unknown try looking up in parts manual from motor model number.
dogdog
Oops! 10,000 uf. Been a while.
Sent from my SM-G360P using Tapatalk
Not sure if there are any 10,000 uf AC capacitors around if they exist probably not cheap or an unusual item. 350V - 400 DC yes and it's common. Besides that motor would have to be monstrous to needed 10,000 uf start capacitor and definitely won't be 3"x1.5" diminsions.
Those cap might have marked with mfd/MFD which usually is uf.
Easiest is for OP to post make model and pic of the capacitor with markings.
exmaxima1
Midwest
What is the Brand of the grinder? Approx age? Pics would really help.
pepi
Woodstock, GA
Does the grinder work, start and run? Makes no sense to take a working machine apart rewire and randomly replace parts. Clean it, paint it and use it a more logical approach.
dogdog
yea those marking are MFD usually means uF . Not MF as in 10,000 uF in some reporting convention.
the one in your link is 10uf capacitor not 10,000 uf.
as far as the op's scenario, best is to post a pic of that capacitor to determine the type.
either beg borrow or steal a multi meter that would measure capacitance.. most meter will be capable or measure 10uf ranges. probably not 10000uf ranges.
wvrailroader
West Virginia
Take it to your local electrical supply store. They can help you determine what size it is and get you a replacement. The local one I use has always been very helpful in situations like this.
Sent from my SM-G900R4 using Tapatalk
bonneyman
Desert SW
The only way to know for sure is to contact the motor manufacturer. They designed and built the motor, and they will know what capacitance the windings need. Since it's an old unit, that's probably out of the question.
So we're back to square one.
The voltage rating can be estimated somewhat, as AC motors run a back emf voltage that's higher than the supply voltage. 120VAC supply would require around a 220v or 250V cap. Going over on voltage rating won't hurt anything. Over is OK, under is a no-no. All that limits you is the physical size of the cap - will it fit? If a 250v will fit, you should be OK.
mf is another guessing game entirely. Best chance - still a long one - is take the OEM cap into a reputable capacitor wholesaler and let them try and determine what size it is. Not great, but looks like all you've got - unless someone else with that exact same grinder can open theirs up and tell you what the cap is.
pepi
Woodstock, GA
You can check the cap it with a meter, see it charge and discharge that's what it does. It will be one of three readings, shorted, open or working charging and discharging.
Davefr
OR
It's common to find old motors with bad starting caps and no specs. I'd start by searching the internet for similar motors and see if you can find a parts list with cap values. Similar motor designs will likely have pretty similar caps.
Plan B is the trial and error method. It's easy if you have a Turbo Cap.
If not, just get a handful of caps with a 220V rating and start increasing the capacitance until the motor starts and comes up to speed quickly. (you increase capacitance by wiring caps in parallel). You won't hurt the motor as long as you make quick trials. Once you find the right value get a cap with that value or one notch higher. Capacitance is generally not a precise spec. Just make sure you get a voltage spec higher then line voltage. (ex: 180-220v for a 120 V motor).
I used that method on my Milwaukie project and 50 MFD turned out to be the sweet spot.
Sometime you can also narrow down the cap's value based on it's physical size. It would at least get you in the ballpark.
Around here, Ace H/W sells motor caps.
At one time there were electric motor repair shops. I haven't seen one in years. The few that are left only do the big stuff.
L
larryq
Thanks everyone. The grinder itself is an old Black and Decker, probably from the 1950s-- the capacitor has no markings on it regarding capacitance or other specs unfortunately.
Definitely the original capacitor in the grinder, which is why I want to replace it-- instead of a hard plastic cover it's a thick cardboard that looks 50 years old.
mikebaker1129
Huffman,TX
You can also have the capacitor measured by some one with a meter that measures capacitance. This will work if the cap is good,you will still have the issue guessing with the voltage rating.
404
Mass
Might be good for another 50 years:thumbup:
exmaxima1
Midwest
The orange cap in that pic does not look like a non-polarized type, as it has a polarity mark. For motor use, you need non-polarized or "ac" capacitor.
pendragon1998
NE Georgia
My block grinder had one of those cardboard wrapped capacitors. I peeled off the cardboard and the specs were written on the capacitor body under the cardboard.
Read post 33 in the grinder link in my signature.
L
larryq
I'll try that tonight, thanks!
Davefr
OR
Ideally yes. Especially for a run (ie high duty cycle) capacitor.
For a starting capacitor with a duty cycle measured in just a few seconds it really doesn't matter.
L
larryq
Ok, as pendragon suggested, I removed the cardboard wrapping and sure enough, the specs were on there. 110 VAC and 72-87 microfarads.
Time to go shopping...I assume I should aim a little high on the replacement, once again using the mcmaster page as a guide:
http://www.mcmaster.com/#ac-electric-motor-capacitors/=10dqc07
...looks like the one listed at 125 AC and 88-105.6 would do the job?
mattblast
Bridgewater, NJ
I would get the 72-86.4 rated one. With rounding that is identical to what you have.
It is rated for a higher voltage but that's ok. Just don't go with lower voltage.
404
Mass
A higher value of capacitance is not "better". A higher voltage rating is fine.
A capacitor is like a spring on a car. A too soft spring is as bad as a too stiff spring. The inductance of the motor is like a mass. The capacitor is tuned to the inductance as a spring is tuned to the weight/mass of a car.
L
larryq
Ok, thanks. (and to 404 too.)
exmaxima1
Midwest
You might do that for your own DIY projects, but I would not advocate that in practice. It doesn't cost much to use the proper (AC) device. Do it correctly and it will last another 20-50 years.
404
Mass
Agreed.:rocker::thumbup::beer:
