tire gauge digital vs dial
goodwrench
anbody have any thoughts on digital tire gauges and digital inflator gauges? i really like the looks of the astro 3018? and I really like the accu-gage dial gauges? so anybody have any thoughts? I believe the astro would even work on my atv tires? seems like the digital would cover a wider range of tire pressures? I really want something durable that I could use for say 5# atv tires to 35# car tires to 50-60# trailer tires. May have to get like the astro for high pressure and a 0-15 dial gauge for the atv... so anybody have any thoughts?
later!! Chris
JJThrasher
Indiana
Analog is generally cheaper and just as accurate. We do have a master gauge at work we use for calibration purposes, its digital, but I wouldn't be using it on tires. I've been using a 0-100 psi dial gauge, before that I used a Blue Point 10-120 psi pencil gauge. If you really want precision at low pressures you're probably best off with an ATV or drag racing gauge.
Backpack Hunter
NC
I have a digital one by Tire Minder I believe. Seems to work fine, but I never had a problem with any other one either.
MrGiggles
All I really use is a Tekton digital gauge. It's a lot handier and accurate than pencil and round gauges, and most cheap gauges won't go past 50 psi.
cheechi
Triad, NC
my digital checker is close enough after comparing it with a dial that I trust. I like an inflator with an analog gage, be it dial or stick. I don't think digital in the inflator saves you any effort.
Thezapper
Toronto, Ontario
The Astro gauge is nice, really nice..... I paid about 120 cdn for it. Best money I ever spent. I was tired of buying cheaper needle type gauges for 30-50 dollar range. Owned it for about a month now and all is copacetic....
Fedwrench
Valley of the sun
Digital is the only way to go especially if servicing TPMS equipped vehicles:thumbup:
The updated Astro unit that uses penlight batteries is nice as are the pricier Pcl, branick, and Ateq, models.
CobraRed
They make a lower psi range analog inflator now that has a more accurate pressure sensor:
http://www.amazon.com/dp/B015NC4DXY/?tag=atomicindus08-20
http://www.autotoolworld.com/Astro-...0apVj81LTx5Wxa3hV--qZsL44K0oL5BsPYaAkCy8P8HAQ
Hondarancher4435
Low pressure atv gauges work well. I had a nice digital gauge don't make the same mistake I did I bought a tractor and didn't know the tires were calcium filled I checked the pressure with the stem at the bottom and it filled the gauge with calcium instantly killing it
Jbullfrog
Avoca, Iowa
I have an Astro digital and it is 5-7lbs higher then any of my dial or stick gauges. It is a pain to change the battery every 3 months, as you have to take screws out of plastic threaded stems to remove the face for battery access.
Vvmvbb
CT
Analog is easier to use. Filling to a line is just mentally less taxing than filling to a number. With digital you are kind of calculating differences and proportions in your head, analog you're just looking at it. This applies to lots of interactive measuring activities.
Indexmill
Central NC
For most home shop folks, it seems that a digital tire pressure gauge is a solution looking for a problem.
gte718p
I like digital, but finding one that is calibrated at a reasonable price has been difficult. People assume digital means accurate, but that is not the case. The last one I had the precision was good. It alway read the same pressure, but the accuracy was way off by ~5 PSI. That is a fairly big deal.
jn50308401
I've got a Joe's Racing gauge with 1 PSI increments i got off of Amazon. It's dead nuts to the TPMS on my 14 Silverado, the Mrs 2012 Equinox, which is fine by me.
I had a Blue Point inflator for years but it finally started leaking so badly I couldn't use it any more. The Joe's gauge and an air chuck do the job for me.
Good luck and Merry Christmas!
Sent from my SCH-I545 using Tapatalk
Here2Learn
Alabama
Not sure how serious you are on ATV's, but I race MX. Tire pressure is set before each ride to suit track conditions. With an ATV tire being even lower pressure, a 10% swing either way would be a big difference. I have an analog for MX use and also have a digital. It only goes by 0.5 psi. I don't like that. It is OK for the bike hauler (aka truck)
BQuicksilver
I too have the Astro. It's a great tool and has matched my Longacre analog enough that I need to eBay the longacre. My batteries last over a year at least, but I agree changing them on the sealed design is a PITA.
zoomzoomjeff
Des Moines, IA area
CobraRed
The new 3018's don't require special batteries or taking the back off. They state using AAA batteries last 4x longer too.
CobraRed
Not a bad tool, but my old fashion dial gauge is accurate to .25 psi and cost half of the Astro one.
No old fashion dial gauges are certified accurate to +/- .25psi. Resolution and experience is different than being certified at a certain level.
I've used the 3018 for years and its dead nuts accurate and has a resolution of 0.1psi, the certification card just means it meets ANSI.
gte718p
Actually there are plenty of them. You can get them much more accurate then that if you so desire. I worked in a research lab in college. We had mechanical pressure gauges certified to .0001 Psi. Of course research labs have little to no connection with reality.
Here is one:
This one is one is accurate to .5% of the range, or .30 psi
http://www.jegs.com/i/Moroso/710/89562/10002/-1?parentProductId=748767
calibrated to .0075 psi and marked .1 psi.
http://www.jegs.com/i/Moroso/710/89552/10002/-1?parentProductId=748767
Most of your professional racers will have a gauge calibrated to .5 psi or better and most will be certified every six months. I admit it is completely not necessary for a normal car.
engineer2
Chicago burbs
±0.25% mechanical gauges are generally not meant to be dragged around the pits.
Most professional race teams (NASCAR, Indy) have high-end digital gauges that can take a beating and stay accurate to about ±0.3 psig. They get the calibration checked annually.
For passenger cars ±2 psig is probably good enough. Most industrial mechanical gauges fall into this accuracy spec if you stay in the middle of the range.
For low profile performance tires ±1 psig would be better if you are picky.
themiller
Seattle Suburbs
Digital. I bought auto-12v inflators this year for the relatives where you just set the PSI and plug it in - it shuts off at the correct PSI. Used one myself (for QC...) and will probably pick one up. Quicker/easier than turning on the compressor and dealing with a big hose.
pacemade
Alaska
pressure gauge readings usually vary especially after several uses. I prefer the pen style, and pick them up used when I find them. When you work in a tire shop you get fix flat in them, they fall in the gutters, fall out your pocket, get smashed, the seals wear out, misplace them. It would be worth investing in a few pen styles. I have seen the digital ones accurate to the hundredths, but the batteries don't last long and break easy when dropped a few times. The dials don't last long either, they get moisture or dropped a few times and loose their accuracy.
TXBDan
On the race car I use a longacre dial gauge. I'd recommend a large sized dial gauge with a good pressure relief button.
SantaAna12
Good to have a couple to compare against a (hopefully) known quantity. I have an analog pencil Milton that is surprisingly accurate. I have other gauges from work on an expanded lower scale, but I am looking for a higher scaled one like the 3018. Its good to know its track record (thanks Cobra Red), as I do not look normally to Astro for things like this.
I added it to my Amazon list.
