Which way does this Air compressor flywheel go?
jcobra99
Im Putting my compressor together that im building. Im just double checking im putting the flywheel on the correct way. Is picture one correct?
akdiesel
Wasilla, AK
I may be wrong but I don't think it matters. One way would be to blow on a cooler or the other way is to cool the pump.
DocsMachine
It blows the same direction either way. The vanes don't reverse when turned around, any more than screw threads reverse when a bolt is turned around.
But the "correct" way to mount that flywheel is with the center pinch bolt on the "outside"- away from the compressor- where you can more easily access it during assembly.
Doc.
akdiesel
Wasilla, AK
Doc.
Ah, yes. Thank you for correcting me.
Cyberbear
California
Try this: you don't spin the flywheel 180 degrees, pivoting at 6 and 12 o'clock. You flip the flywheel at 3 and 9 o'clock to reverse the vane air flow.
pattenp
Virginia - USA
Also if the blades are concave there is a difference which way the wheel goes on. You want the concave side pushing the air.
Techie1961
Pickering Ontario Canada
The second photo looks like the right way. The little tail on the vanes is usually pushing the air, not grabbing it. Due to centrifugal forces, the air will build up on the perimeter more and this helps to push it faster.
J
jcobra99
ok thanks everyone. Whats the best method to get the flywheel on the pump?
FTG-05
TN
Question about compressor flywheels:
Are they cast iron or cast steel, typically?
Thanks,
DocsMachine
But I think he wanted to know which way the blades should face. The fan can be set up to blow air towards the motor or the fan can be set up to draw air over the motor and then through the fan.
-No, it can't. :D
Flipping the wheel around doesn't change the direction of the blades. At worst it might put the less efficient edge leading, if we assume the makers actually put any aerodynamics in the fan blade shapes.
But the only way to reverse the direction of the air flow is to reverse the direction of the motor itself. (If there's an arrow cast into the wheel, it's indicating which direction the compressor is supposed to spin.)
Doc.
