Uninteruptable Power Supply Power Box question
Junkman
Northeastern CT
I have just spent a lot of time reading, and rather than ask my question in one of those other threads, and muddy the waters, I will start a new thread.
I recently was given an electrical box that came from a manufacturing facility, and the box says to only power it from the master uninterruptable power supply. The box consists of five 110 volt 15 amp receptacles, and one 30 amp 4 prong receptacle (L14-30R). At the end of the power cord that is attached to this box, is a 4 prong twist plug (L14-30P). The 110 volt receptacles have individual push button circuit breakers. I opened the box to see how it was wired, and all the 110 outlets have their ground wires going back to a single stud on the case, and the green wire from the 4 prong twist plug goes to this terminal. Half of the black 110 volt wires go to the red wire on the L14-30R receptacle and the other half go to the black wire on the L14-30R receptacle. The 4th wire is yellow, and it goes to the silver terminal on the L14-30R, along with all the white wires coming from the 110 receptacles.
I understand how I should wire the receptacle that I want to power this box at my electrical panel (white to neutral, green to ground, red to one terminal of the breaker, and black to the other terminal of my 220 breaker).
Now, for the question, why isn't there a green jumper wire from the case to the green terminal on the L14-30R receptacle? And, why is it that they specify that this box shouldn't be powered from any other source except from that uninterruptable power supply?
Alchymist
Central PA
I'm guessing the L14-30R receptacle is self grounding through the mounting screws.
As to the specification about where the box is powered from, it's probably that the box was part of a larger system and the warning pertained to the use of the box in that system.
J
Junkman
Northeastern CT
Thanks for the reply. My next question, is could I make up a jumper cord using a L14-30 plug on one end, and a L6-30 plastic receptacle at the other end? I would like to use this box on the wall near my lift, which is wired with a L6-30 plug on the end of the pump.
wyliesdiesels
Modesto, CA
So u want to power the lift from this box?
