We have them but only just above vent stacks and exhaust vents. The roofing co. that installed them just made them up from flat stock in their shop.
Our roof is nearly 45 degrees so when it slides, it really comes down hard. Didn't have them installed at first and when the first heavy snowfall came, and then it started to melt and slid down, it wiped out a few of the plumbing vent stacks. Not nice... We also had a lot of our gutters come down because the installers didn't put in enough hangers so it all got redone and with upgraded hangers.
You want snow guards if you have entry doors, sundecks, sidewalks etc. - anywhere that the snow could land on someone or pets. The roof over those garage doors should have them. Maybe just one continuous row part way up, or could be maybe 2 needed. I would talk to a roofing co. experienced with metal roofing and snow blocks. They are easy to install and don't take much time on site. They get screwed into the top of the standing seams and never into the flat piece against the roof sheathing (as I've seen in some photos). The metal expands and contracts and needs to be free to move, plus screws into the sheathing could be a cause of leaks.
There are different products on the market and different methods for attachment. The drawing below shows one method using set screws against the side of the standing seams - looks expensive tho. Ours is like in the photo. Google "metal roof snow guard" and you will find lots of info. and photos.
Don't know if you had the roofing installed or bought the property with the building already completed. Metal roofing installations have long manufacturers warranties. 40 years for this company -
https://www.classicmetalroofingsystems.com/product-info/warranty/ or even lifetime for some. Contractors can warranty a metal roof for the labor for well beyond a year for metal roofing. Before you do anything to the roof, you want to make sure you won't void a warranty. You may want to use the original contractor/roofer due to potential warranty issues, unless it was installed by the homeowner.
