Robbins & Meyers Fan Restoration
Scimonetti
VT
Robbins & Myers Fan Restoration
I picked up this fan at a garage sale this summer and finally got around to working on it. Pretty sure I paid 8 bucks for it, had a horrible house paint repaint job and bad wiring but it turned on and oscillated!
Here are the before pictures, I'll update my progress tomorrow. Need some motivation to work on it!
countryroad82
Kentucky
Very nice! I love those old fans. I've got a few myself but don't have the heart to do anything to them other than run them every now and again.
Kevin54
MEMBER EMERITUS
Urbana, Ohio
Nice. My uncle was a tool & die maker for them, and the factory was only about 20 minutes from me in Springfield.
don long
southern california
Do you want to double you money lol
That is one very nice fan.
I have started collecting them but haven't had the courage to tear into one yet so I will be on this thread like a bee to honey
Don
Scimonetti
VT
Thanks! This is my first one, they are incredibly well built. Not sure on age but somewhere in the 20s-30s
Oh that's awesome!
Don
Thanks! I am considering selling it when I'm done actually. I personally don't have a place to keep it and actually use it an enjoy it, so I think I might try and find a new owner for it when I'm done and add the profits to the lumber budget :beer:
Scimonetti
VT
Ok, so here's a brief progress update. I'm in a productive mood and looking to bang this out!
I started out a couple day's ago by unbolting the wire guard and using a pulley/bearing puller to remove the 16" blade. The guard sat in the electrolysis tank for 2 days before I started the project tonight.
Imho there is no other way to strip one of these delicate cages down. A powered bench wire wheel will catch and bend the wire frame. Chemical stripper would be a mess, I highly recommend electrolysis, leaves nice bare steel throughout all the nooks and crannies.
After it came out I dried it and went to town with handheld wire brushes. about 35 minutes later I got a couple stubborn spots with the drill and then did a super quick scotchbrite.
Here's the base plate with capacitor and some other stuff I'm not sure what it's purpose is. I cleaned it up using compressed air and a toothbrush on the inside, and cup brush on the rusty steel on the bottom. No pics, i'm just going to put felt under it. Also pictured it the (Nickel?) plated flag badge. Not gonna mess with it.
This is the little exposed wheel I used to clean up the base and hardware. It took about 15 minutes with pliers to get the little nuts and screws cleaned up and the base raw. From there a little love from the green scotchbrite gave the base a nice brushed steel look. I tried to salvage the original japanning by removing the brushed on enamel with acetone, but only found rust underneath.
By unbolting the motor end bells the rotor was exposed. I made sure to keep the washers in place and used mineral spirits, a nylon brush and compressed air to clean out the rotor and windings.
Mineral spirits on a rag and a nylon toothbrush cleaned up the original finish on the motor housing. I had to use #0000 steel wool to buff out some house paint splatter from the japanning. Of course I disassembled the brass pivot sleeves, and cleaned up all the hardware and grime from that whole oscillating assembly.Also pulled the gearbox apart, flushed out the old peanut-butter-esque grease and replaced it with some modern synthetic stuff.
Where i'm at right now.
I just put the blade in tonight, we'll see how long that takes until the paint softens up. Just like a good rack of ribs, it should be just about ready to fall off by itself.
The blade will also need some balancing, here's a site I found. http://www.afcaforum.com/forum1/24048.html
Featuring guys that actually know what they're doing! There's a lot of great reading out there from collectors if you are interested. Consider this to be an entertainment thread, I have zero clue about proper techniques but am just having fun in the shop!:thumbup:
Scimonetti
VT
Nice work there Scimonetti. The fan is looking fine.
It's obvious this is not your first rodeo
I appreciate it! I tend to mess with a fair amount of rusty tools and things, but I am far from experienced. Pretty sure I've learned almost all of the little tips and tricks from everybody on this forum, and then the rest from just doing.
The blade came out well
It's taking me a few days to do the paint job, been scuffing with 800 grit in between coats but it should be dry tomorrow.
http://vintagewireandsupply.com/rewire-cords-restoration-kits/
Also just ordered one of these cord kits in charcoal and will be putting some black felt on the base. Can't wait!
Scimonetti
VT
Re: Robbins & Myers Fan Restoration
Parts just came in! Still waiting on clear coat to dry but will put on the felt soon
Sent from my 710C using Tapatalk
