Not so common must have tools
Fedwrench
Valley of the sun
Let's see, a few of the things I have in my cart that I wouldn't want to be without:
Powerprobe 3
Waekon coil on plug tester
Waekon fuel injector tester (probe type)
Universal noid light
1/4 drive magnetic sockets & magnetic nut setters
Flex probes
FEVERinc
Central Florida
Powerprobe 3
Flex probes
Love my power probes! Can't function without them
bwringer
Indianapolis
20 ton hydraulic press. Frankly, I'm amazed at how much I've used this thing to press bearings, bend metal, squish stuff, and generally apply large, well-controlled forces to stubborn things.
My favorite weird setup was making a custom exhaust adapter by pressing a short piece of pipe onto a trailer hitch ball to stretch one end. Worked unbelievably well.
Slightly more obscure is my DC amp meter. Most amp clamps only work on AC, but for work on motorcycles and cars, a DC amp clamp is incredibly useful. After searching high and low, I finally found a reasonably priced version at Sears -- $60 for the Model # 82369. Sure, it's not .0001 amp accurate like your mega-$$$ Laboratory Grade Fluke, but for chasing mysterious battery drains, catching bad coils in the act, etc. it's been fantastic.
Tech89
SO ball joint press. It's the best one. I don't have this set yet but I want it. Only problem is that i have a hard time spending 700 bucks on it. I'll get it on eBay for 500 soon.
Sent from my Nexus 6P using Tapatalk
I agree. I love mine. Broke two others before I got the Snap On. No problems with this one and I use it regularly.
-Pat
Sent from somewhere in Minnesota
gooseadrian
A tool I made to press in hydraulic ram bushings on concrete trucks for the drop down axle.
I actually have a few home made tools I use for these dam trucks lol
gooseadrian
JIC cap and plug kit. I do a lot of hydraulic stuff
Tech89
An accurate tire pressure gauge.
Just had a problem with this on a customer's vehicle the other day. My gauge was accurate and his wasn't, he thought his cheap little gauge should be just as accurate as my Milton. Vehicle and Tech 2 said mine was accurate. Dunno.
-Pat
Gmonkee
The nut breaker I have is well used. Pretty much the rest of my job it's simple and basic tools every day.
KraftwerkMk1Jetta
Long Valley, NJ
Slidehammers. You probably won't use it everyday, but it's damn nice to have on when the situation arises.
I use the Snap On light duty hammer with the two jaw puller to remove bearings and seals on golf course mower rollers all the time. Nice tool to have IMO.
