blown in attic insulation
jevoy
Northern Ontario Canada
Hey there. Just curious if anybody out there has just stapled up 6 mil vapour barrier to the bottom chord of the trusses and then used blown in insulation on top? I know drywalling first is a better idea but its a cost thing right now. I know of one person who has done this and it was fine. Anybody ever have a "cave in"?
Thanks
AldeanFan
Niagara on the Lake
My garage was vapour barrier with r12 bats when I bought the house, no drywall. The insulation had dropped significantly in spots and stretched out the plastic. I had to pull a lot of it down and re-do it. Took a few hours extra to get it drywalled.
soapii
SE Michigan
I have not seen plastic used, but you can buy vapor barrier that is like a fabric mesh that is used specifically for your application. They did it on my garage prior to drywall to blow insulation under the floor of my attic.
You can see in the attached picture. The center fabric area has 10" of blown cellulose on it with no noticeable sag.
--Joe
MBfreak
MEMBER EMERITUS
Linkoping , Sweden
My $0,02 worth.
If at all possible put a rather thick paper cover (( is is called "kraft" paper??) must not be vapor-tight) on top of the insulation. This reduces the air circulation quite a lot inside the insulation and reduces heat loss.
This is a requirement in building codes here in Sweden, so for cold climates I am sure it´s worth the effort.
If you live in a warmer climate where ambient can be above if the space is cooled in the summer, I have no idea what is right.
Best regards
Ola
nolimits76
Oklahoma
FYI, if you guys check at the local contractor supply houses, you can find thicker 11 mil & 16 mil vapor barriers. One popular one around here is called Barrier Bac. The VB250 is only 11 mils, and the VB350 is 16 mils.
http://www.barrierbac.com/
This stuff is much better than the 6 mil visqueen you get at Home Depot and similar. Whatever product, I used roofing nails with the fat plastic washers.
Alternatively, I've used blown-in-blanket (BIB) insulation in a house before. They use a non-woven fabric material to hold the material in-place. It may be a better option. It is similar to a garden fabric material but not identical. Doing some web research it appears that Owens Corning & Certainteed both have a product.
http://www.bibs.com/
http://www2.owenscorning.com/literature/pdfs/10000560.pdf
http://www.certainteed.com/Products/317369
NUTTSGT
Northern Central Ohio
I'd be afraid of it pulling through the staples. If it pulls through, you are going to have a mess. I've dug enough blown-in insulation out of attics to know I wouldn't want that mess in my garage and everything in it.
FWIW, you might want to edit your profile to show a location to help your fellow members answer any future question you might have. You don't have to be specific but just a general location of where you're at in Canada might help.
csp
Franktown, CO
Tyvek shouldn't be used between an interior space and insulation, only outside of the insulation. Tyvek isn't a vapor barrier, it is permeable to vapor passage which you don't want in the insulation.
Elginz
Oconto, WI
I would go this route.
DC73
Lubbock TX
Walls must be able to dry. If there is a vapor barrier anywhere in the wall assembly, then walls must be able to dry to both the exterior of and to the interior of the vapor barrier. Not all climates need vapor barriers and it can create problems if not installed properly. Depending on the climate and how the rest of the wall assembly is constructed, using Tyvek as was suggested would not be a problem at all. IF a vapor barrier is required, then Tyvek should not be used in its place.
DC
