52wrench
Hi,
First time poster, great website. I thought you'd like to see what I did to mine to get rid of that uneasy feeling of it cratering in when I'm under it. I had 4+ inches of concrete and the anchors all went in fine but this eliminates any concern. The main tube is 3" 6061 .125 wall tube. The outer tube is 3" sch. 40 pipe that is a slip fit over the main tube. This is set up so I can use it with my lowered 911. The 911 floor pan is about 5" off the ground so the top of the tube can't be over that, I set it at 4". That put the bottom of the tube below the bottom of the carriage so I added a piece of 1/4 plate to the carriage so the tube has full bearing. I will have to make custom adapters for the 911 so the pad is not more than 1" below the jacking points, otherwise the tube will hit the sills or pan before the pad contacts the lift point. The dimensions between the posts have to be even top and bottom to prevent any binding as the lift is raised. To use it the car is positioned then the tube is slid under the car and put into the short collar then other collar is slipped over the two bolts on the carriage plate and the pin is inserted to lock it.
