dhubbard422
Hello,
I thought I'd start this thread to see if I can get the lighting experts to chime in with thoughts regarding lighting/illumination guidelines for all of us non-experts.
There are so many threads that touch on this subject. I have found Platonic Solid's layouts very helpful. Other's have also posted various "rules of thumb", which are also helpful, BUT I wonder if there are more!
Here are some that I've found.
Recommended Lighting Levels: Is there a better guide than this?
http://www.engineeringtoolbox.com/light-level-rooms-d_708.html
Schrodingers Cat posted - 60% rule of thumb (for "effective" lumens)
http://www.garagejournal.com/forum/showpost.php?p=646892&postcount=44
But, I wonder if that 60% RoT could be further refined based on ceiling height?
I found several layouts (created by Platonic Solid) for shops with 12' ceilings (the ceiling in my workshop is 12'...). His layout examples typically seemed to aim for (roughly) 80 - 90 "effective" lumens on the work surface and the difference between claimed bulb output and "effective" lumens on the work surface was roughly 60% (in his examples for spaces with 12' ceilings).
I've also seen a RoT for light spacing (between rows of flourescent lights) that was something like - not further apart than the distance from ceiling to floor (or was it ceiling to work surface?)
But what about a RoT for distance from workbench? For example, I want really good light on my workbenches, but does this mean that I need a row of lights right over my workbench? Centered over the workbench? Directly above the front edge of the workbench? Within a couple of feet of the front edge? Or?
Many of Platonic Solid's Layouts, which generally seem to use 4' tube style lights, often placed several lights between the primary rows at 90 degrees to the rows. Usually at the (end) walls between the ends of rows of lights. I'm guessing that a RoT might be that workbenches are often/usually against walls so put lights there. But, I also wondered if helps produce a more consistent, even illumination if some bulbs are place between the rows where these bulbs are rotated 90 degrees to the primary rows?
Are there RoT for materials? White metal ceilings vs white painted drywall? White walls vs wood walls? Racedeck vs polished concrete? What impact would materials have on the 60% RoT?
What about aging and eyes? I've started my 6th decade and well... I need a lot more light now (for detail work) than I used to and I doubt it's gonna' get any better! Any guidelines?
Thanks in advance! I hope that this thread can generate some good discussion!
