Ihateclevernames
Gents, I know there has been alot of talk on here thus far about heaters and what not.
Especially for those of us who are still working on our shops without power, or natural gas. I picked up one of these today and am extremely impressed.
http://www.grainger.com/product/MASTER-Kerosene-Forced-Air-Heater-32MY51
I was exploring radiant heat options and eventually settled on this as i always have a significant amount of diesel on hand here on the property, so i figured it would be the most convenient. The instructions say that kerosene is best, however i would like to continue running diesel in it, unless of course........
Some of you disagree and have experience with this heater. I was thinking maybe run it with kerosene every so often to clean the lines out and what have you.
Overall, I like that it doesn't use a ton of electricity and can be filled with a trip out back to the fuel tank.
Any tips on this type of heater and maintenance?
I will eventually be moving to a wood stove of some sort in the shop as i also have access to alot of timber on the property and could use the abundance of downed trees each year to fuel it. So, overall this is a temporary solution. one that will not eat up propane at $2.59 a gallon and will be multipurpose. My shop is insulated with R-19, so that helps hold the heat it. I heated up the shop in about 15 minutes earlier, so we will see how well it does when it drops below freezing tonight.
