One of my minions fond this one. Clearly some condition issues. I think it is a Prentiss because of the split slide. I think there are cracks in the towers where the pipe jaws would fit. Clearly a pre-1900 vise. Bolt through the counter.
Anyone have an idea on who made this??![]()
On my way to pick this up!! Always wanted to get one of these.![]()
Tops, I have a few pictures of this stamped 1-74 Wilton. Check out how the 4-1/2 jaws are bolted on and how much taller they are. Does anyone know anything about this model. Built in Schiller Park. Kind of a different Wilton model. #101115 on the side.
I must not get it but why does a vice matter that much on price. I can't see why a vice from menards wouldn't work for 99 percent of the time.
Certainly is an odd one from Wilton. Styled like a pattern makers vise. The one in the picture I posted has some issue with the lead screw...
this vise has 1 3/4"wide jaws and overall length is 5 3/4"-question what could its retail value be ?
I can understand quality but some of these are insanely expensive. Also Toyota tends to fail too [emoji11]The same reason why you choose between a Toyota instead of a Yugo if you want something that will last. One is built better. (Hint : It isn't the one that was built in a former Soviet factory)
Hey guys. This thread made me grab this vise that was laying on a skid in my shed. Used to be my father's, i think it was the one in his shop about 20 years ago. Just wondering if it is worth fixing up and if so, some instructions on the best way to do so using the methods which will achieve the best results. Thanks in advance!
*** or a link to "restoring vises"... but I'm still searching. This thread has so much good material.*** but would still appreciate feedback on my Parker vise.
Yours picture shows a Power screw Wilton, I believe it uses a hydraulic set up to tighten tighter then the normal way. I thought Oldie had a cut away view of this setup. Maybe the one I show is ONE without the hydraulic spindle setup. Here is a LINK to a power screw by Wilton post created by Craig (Catalyze).
Saw that earlier, always wanted one of those too. But I'm not really a fan of those under the bench swivels. Curious to see if that flange goes to the vise or not.
Good luck, Jim
Just noticed he claims the base is "geared"... haha
I know... I own a 5197... the same locking mechanism as was used on most old vises...The base has teeth that engage teeth on the swivel lock......sort of an indexing effect.....I guess after a couple pops it might resemble gears....
Hemi
------------------------------------------------------------------------$412.61
Hello everyone, I am new here, just signed up. I was trying to find out info about my old vise on another forum and was directed to your forum and the quoted post #7344 on page 368 of this thread.As a comparison, here's a No. 7 I saw online recently.
So yeah, I have a "No. 7" vise that belonged to my father-in-law. From what I have been seeing, it looks like it was made by The Charles Parker Co. Perhaps, due to lack of makers mark, it was produced for the discount stores such as Ward's? Same as cast iron cookware was produced by the big name makers, but without their names on the pans for the discount stores.
I had no clue that vises were collectors items! So maybe I should clean this one up.
Kmot:
Welcome! You've come to the right place for IDing an old vise. (But maybe not a great idea to say you can't read previous postings.). Anyway...Welcome to our crazy world.
My first impressions lead to Parker but the crack in the middle of the slide in the back hints at Prentiss. Many if not most Prentiss vises show a hairline crack back there. Parkers had much stronger reinforced slides (AFAIK) much less likely to crack. The shape of the nose doesn't help differentiate.
So who made your FIL's vise? HELL IF I KNOW!
That upswept swirl in the back is very unusual so that might be your best bet at figuring out who made it. The type of swivel lockdown going through a hole in your bench dates the vise
as REALLY old. Like late 1800's maybe. There was probably a threaded piece extending downward through the bench top so the vise could be tightened down from below with a big rather elaborate wing nut.
Kmot:
I wonder if Parker had the same splitting slide as Prentiss, might be shortly after this vise they got their act together.
Nuts
I can't read through near 2000 pages, so if anyone has input on who/what/where about the No. 7 vise it would be most appreciated.
Thank you.
Bag, how did you arrive at that figure?---Are you just spit-balling?
Econ.
