Flourescent light over garage door solution
OccupantRJ
Eastern North Carolina
My garage door in the shop only has 2-1/2" clearance to the ceiling, but I wanted a 2 bulb fixture in that location. The normal 2 bulb fixtures would not let the door clear. After a bit of head scratching, a solution was reached. A narrowed 2x6 was mounted on the ceiling, and 2 single bulb units were mounted sideways on the 2 by.
Incorporated in the 2 by is a 4" square junction box for the electrical. The fixtures were screwed to the wood to make it a single unit, then the wood was screwed to the osb ceiling. The unit is now only 1-3/4" high. Cost was $8 more than the standard fixture. A side mount single bulb fixture can be had, and are relatively expensive, but this way I got two bulbs for less money outlay.
AndrewDouglasBird
Vancouver, WA
I had a similar issue, light fixture hung down too low. I was lucky though and the garage was unfinished, so I just ran two 2x4s across the ceiling joists and recessed the light up into opening between the joists.
O
OccupantRJ
I was considering doing similar to what you did, but came up with this while shopping for lights, so went for it.
Off-Street Parking
Midwest
FYI the Feit LED fixtures from Costco are only 1 11/16" thick. They're inexpensive, work great in the cold, and no modifications or custom work required :)
Jeepman5112
SAMs has 4 ft LED's for $35 bucks.
I hung 4 today, great investment!
The bright white opposed to the yellow light is amazing.
