Single-post lift. Downsides?
Danglerb
SoCal
I don't see a big advantage over scissor lift that costs $1000 or so less. Both block the middle of the car, one is obstructed also directly under, the other to the side. Lots of cars are going to be pesky opening the driver door to get out when parking over the lift.
OTOH having a scissor I naturally miss the benefits of a two post like parking one car under the other one.
O
omowright
Freetown, Sierra Leone
Thanks, food for thought. If I can park another car beneath then I should prefer it over the scissor.
Really, I was thinking in terms of the mobility and the savings on not constructing special floors for multi-post lifts.
I figure that this kind of lift is relatively new and not many experts have been conversant with it. I would be grateful for as much information on it as possible ...
G-Ram
NWO
Look how uneven that thing lifts, doesn't look too happy.. Wouldn't catch me under one, that's for sure.
ultgar
New Jersey
Kind of agree..........if I had that lift, I'd be using some tall adjustable support stands for an extra level of security.
SD
Danglerb
SoCal
Single post lifts are not new, some very nice ones have existed for years, but not cheap or for the most part suited to commercial use in the US, some though in EU.
Cost of prepping the floor are trivial. Most slabs are fine as is, if needed you cut two larger than post sized holes and mix a batch of concrete in a tub and pour a deeper section. Look at some of the many installs in the lift threads.
Australia
That is the idea. Cost of 6 or 8 solid under-hoist stands will not near the cost of preparing the floor for 2- and4-post lifts.
What needs to be prepared with floors? I thought they just bolted onto the floor.
It's just a big forklift. I would happily use one.
fatfillup
Finksburg, Md
I admit I am squeamish under a lift. Have worked under them some. Much prefer a 4 post lift with ramps you drive on. You don't need to be near as smart to work safely under one of them.
Obviously, 4 posts take up a lot more space.
O
omowright
This is the most consoling post, so far, for my fear of floor preparation expenditures. I've seen posts recommending 6' deep sections. Can't have this on my granite rock compound ...
L.Cheapo
I wouldn't feel comfortable underneath a vehicle yanking on a suspension component with a large prybar with one of those lifts. Just doesn't seem all that stable.
That, and it wouldn't lift half of my vehicles.
So if your concrete isn't near perfect, you have to carry a selection of shims around? How long do those take to set up? Seems a bit dodgy.
