Mostly empty, but there is a little rattling. Tools are all in the stacks.[emoji38]Are they empty or full? Nesting boxes perhaps?
my new to me 1972 combo! 3rd owner, the first owner only had it for a week before he snagged a Snap On box in early '73. Haven't taken it out of the car yet, but no dents or dings, a tad bit of rust, nothing major. Red's all in good shape but the gray needs to be resprayed. Pretty solid for being 43 years old!
Edit: Top is a 65262, mid a 65212, and bottom a 65039. Top and bottom both stamped 11/72!
Rillysan: I found this bottom box on CL and when I posted it here Drives said that what I needed was a top box to go on it. Thanks Drives! Since then I have stumbled across a couple.
It is, & I have one that is externally identical. But instead of the lift out tray in the top mine has two trays on slides like in a regular toolbox & when you open the top they slide outwards.ZRX, I think that box is from this setup circa 1954:
That is a great looking setup Rick. CL score? I really miss the Philly CL used to get stuff off CL all the time when I lived in Bucks.
Yes it is. So that's two of us who have one of themOK is it this one from '49?
I spent a few minutes one day trying to remove the slides for cleaning, no luckYes my round top is like the 1949 ad with the delicate sliding trays, add a little dirt/grease and a ham fisted operator and you could have a mess.
Rag: I agree those old wood boxes are a lot cooler looking than just the plastic storage boxes. Nice to see your Gramp's old tool boxes found a good home. thanks for sharing.
SD: i do like those old Beach top boxes and have one from about that time frame too that looks almost new like yours. that Craftsman crowntop carry box is most likely late 60's with the nice metal handle. i have the Heritage one that is similar that i use almost daily.
Crowntop boxes with that design changed to a plastic handle, but i'm not sure when. maybe the mid 70's. maybe one of the guys with the Craftsman catalogs handy can say for sure about your little carry box.![]()
My dad's old Craftsman, not sure of age,............
There are some beautiful boxes on here. I especially love the early to mid century art deco boxes I have seen. Hopefully some day I wil run across a set for myself. Heres a few of my boxes. First up I have a stack that I got from my grandfather before he died.
ok. figured out how to remove the slides from the sliding cantilever box. All it took was the right size cable tie & a few taps in the right direction
edit:
& that was an exercise in futility.. after cleaning & lubing the slides etc they're just as stiff as they were before...
super cool score diesel.
you have a good friend to hook ya up w/ that beauty.
from the few pix id say that chest is easily mid to late late 40s![]()
DD: that Gertsner looks sweet and that book is the bible to a machinist. nice find and great friend too.
DD
Gerstner actually sells an oil for their boxes. I'm sure the oil can be had elsewhere but as I recall it was cheap. I do not think it had any wax but it does make the box look great. They can also ident the year for you. Check out their web site.
I have a few of these small snap on boxes but this one with a sliding drawer is one i am most fond of.
[/URL][/IMG]![]()
The slides and the leverage angles involved are the problem. Evan empty they don't want to move smoothly! I think it was a neat idea but a sorry design. The round top with a lift out tray would end up being more useful over the long term.
I have a couple different Craftsman boxes;one of them being the same as yours. When I first acquired it the trays refused to close even when it was empty. I found out the problem was where the hinges attached to the top.The metal was thin and not reinforced there which allowed it to bend inward. Didn't take much deflection to cause it to malfunction. After straightening it works with a little assistance when closing.
The other one looks identical outside but has a lift out tray whose handle forms the lock platform. The lock has a double sided hook that engages both sides of the top when turned.
That's def a major part of the problem. Next time I get the urge to piss with it I'll go with wax. The stuff that was in there appeared to be old Military Spec "fuel lube"Are these the "sandwiched" slides with two pieces spot welded together?
have the mating slides worn so they are pointed and wedging into the V notch? Maybe they are shearing the lube so the wedge formed grips tight?.
