HolySheet!
- Joined
- Jan 13, 2016
- Messages
- 2
Hello,
I have a DeWalt D55168 compressor. Link below.
http://www.homedepot.com/p/DEWALT-15-Gal-Portable-Electric-Air-Compressor-D55168/100497924
Two problems:
1. The compressor will not shut off. It builds pressure to about 200 psi and blows the relief valve.
2. The pressure coming from the tank even when the tank has 200 psi is very low. It will barely run any air tool. I removed the hose out of the equation and hooked tools directly up to the valve on the compressor. Same problem, just enough pressure to spin my orbital sander, but you can stop the sander from turning with a finger tip.
Could it be a bad pressure switch and bad regulator? Will either one cause both problems?
Any ideas?
Thanks in advance.
Two problems:
Any ideas?
Thanks in advance.
