let's see your craftsman block grinders
G20-Budo
Chandler, AZ
Found this grinder today at a garage sale.
Looks rough but runs like brand new.
Bought it and a 9" sander.
$15 for the pair.
Any idea on its age?
Reversepolarity - I just wanted to say.... YOU ****! Great buy there!! :thumbup: I've been on the look out for a 3/4HP block grinder, haven't found any around here.
drivesitfar
RP: not that i know of. that hole should be the bigger water tray with that nice hefty tool rests coming out of it. since i have yet to own, find or see one in person i'll let the others maybe give a better answer.
again nice pick up and post it up again after you clean it up a little or use it and clean it next year.
McBrownie
Cleveland, OH
$15 for the pair.
Nice find! A 3/4hp cap start commercial probably from the mid '70's given the cast iron tool rests. Not an original switch, but it will clean up nicely and is a heck of a grinder. Congrats!
Edit: Oops! It's a split phase, but still a great grinder. Go back a few posts and you'll see a link to a Sears catalog with that grinder in it.
JZiggy
Atlanta
Guys, can someone direct me to the Rustoleum paint colors that most closely match the flat-top 397- model grinder? Like Torqueman's below:
G20-Budo
Chandler, AZ
Does anyone on here make replacement stickers for these?
RP - A ways back in this thread you'll see that someone made a template for it. I got a copy of the template and make a change with a font that was a better match for craftsman. If you PM me I can send you the word file and the font file. Then you can take it to a print shop, or kinkos/fedex, or you can just get the correct kind of sticker paper and make it on your printer at home.
Just let me know.
Bobioz1
Northern il. (For now)
I use all Rustoleum products, Wheel paint in graphite with Chrystal clear cote. Center tin gets metallic silver with Chrystal clear cote. Looks perfect to me.
McBrownie
Cleveland, OH
The later 257 flat tops had more of a light gray on the center tin, but I repainted mine metallic silver and then clear coated it. It looks much better in my opinion.
Isaiah6113
Oshawa, ON
+1
I'll get in on this . . . Me too! I use Rustoleum Metallic Aluminum for the centre band.
As per:
Wee bit of glare, but best I have.
A little easier to see maybe:
Matthew A.
JZiggy
Atlanta
Awesome, thanks guys!
I am a spray paint n00b. Can someone advise best practices for application of primer, paint, and clear coat? As in # of coats, light vs. heavy, time between applications?
The back of the primer can says to "topcoat within 1 hour or after 48 hours." Is there a benefit to waiting the 48 hours...?
drivesitfar
JZ: until the REAL paint pros give instructions. PREP is the KEY as i've put in my sig line. ideal paint temps are between 50 and 80 with 65 probably being optimum. i'd wait until first coat fully drys before painting second and third coats. you'll need to rough up surface some before painting either primer or paint. also not all paints need primer.
some of the guys flipping vises actually bought some $100 smokers (on sale price) at their annual tractor supply stores and the paint and then set in the smoker on 200-300 degrees to bake the paint on with AWESOME results.
as mentioned good prep and good temps will help a lot. also if you happen to want a hammered finish you might need to spray on a bit heavier to get the look you like.
setting up a temp paint booth with plastic stretched across 2 x 2's might keep paint spray contained.
good luck
torqueman2002
SE Michigan
Nice.
Now, if only I could get that label to you. :eek:
Update.
Success!
A zip file, containing an editable MS Word file, has been added to the "What's the Fuss" thread (link below, in sig. line), for a 3/4-HP ftop Block m-397.19451.
torqueman2002
SE Michigan
Pulled it off the thread.
Worked great.
Thanks for the feedback, good to know.
Being a MS Word document, it is not that easy to edit; and for that I apologize.
I do not have any desktop publishing or photo editing experience/software.
I know there are better ways, but this works for me and anyone is welcome to use them.
:thumbup:
G20-Budo
Chandler, AZ
JZiggy,
That CitriStrip seems to work very well! I might give that stuff a try in the future on a few of my projects (my block grinder being one of them..)
mroneeyedboh
Does anyone have a dirty old block grinder they would be willing to sell? I'd like it complete and 1/2-3/4 hp. Sorry of this isn't the right place to ask, but in the classifieds it may get missed or maybe someone may not be thinking of selling one and then maybe decide... Anyway thanks.
JZiggy
Atlanta
JZiggy,
It worked well to let it soften the paint for about an hour, brush with a nylon brush and a fine brass brush for tough spots. Rinse. Wherever the paint is still stuck reapply and give it another hour.
JZiggy
Atlanta
Don't let citristrip touch anything plastic!!!!
A drop fell on my caliper gauge lens. The area hazed and formed a large stress crack. Powerful surfactants can really wreak havoc on plastics.
Reversepolarity
Washington State
Where are you located?
JZiggy
Atlanta
Rustoleum Graphite Wheel paint for the castings, Metallic silver for the band. Gonna order a new band from Sears I think.
McBrownie
Cleveland, OH
Located in MD. I may have one available local, my neighbor says he thinks his dad had one... Hope so!
There was a 1960's 1/2hp round top commercial cap start by me for $50. It was missing the right hand wheel guard, which means that I could have put a multitool belt grinder on it for "only" a few hundred more. Luckily, it sold. Whew!
Kaervak
Cleveland, OH
Heh, that was mine. I picked it up for a reasonable price and borrowed some parts from it to complete my other 1/2HP block. It really did look rough, but it ran perfectly. These blocks are bulletproof. :)
McBrownie
Cleveland, OH
Aha! I showed restraint. I bet it ran great. It was worth what you were asking. Hope you got it.
S4cruiser
NC
Picked up this guy earlier today. 1966 date. A month ago I had zero blocks...now I have 3 of the exact same model. How did this happen??:lol_hitti
It looks worse in the pics than in person. Just very dirty.
