duwem
I was thinking 30' deep would work real well, truck is 20' long, would give room for a workbench in front and room to work all the way around a vehicle.
Then the pole barn guys (2 different companies now) said that if I want to put steel on the ceiling for blow in insuation the trusses need to be 8' apart to handle the load/ for the steel to span.
Sure I could go up to 32', but I'm going to have an area behind this and only have about 48'-50' total depth work with so I loose more area in the back which will have a loft. 24' seems like its going to be pretty tight....should I just go 32'?
