Finding bolt head size
mjoekingz28
Mississippi
I got the bolt thread size, male and female, chart on the list....but how do you tell what size the bolt is without narrowing it down by playing Cliffhanger from Price is Right.
I guess a measuring tape could work, but my measurements arent accurate. I compared my rulers to tapes and it is difficult to tell where exactly they start and they do seem to be off by a 1/16 or so. Like when I was trying to measure my bicycle chain, they say, like, for every ten links should be a foot I believe and a quarter of an inch means the chain is toast.
Katodog
Carol Stream Illinois
After over 30 years of maintenance and machinery work I'm able to look at most common hardware and know what size wrench I need. For thread count, shank size, etc. the two best things to always have is a caliper and a bolt gauge.
OutsideMachinist
Norfolk, VA
Measure the bolt head or nut. Measure the diameter of the threads. Use a ''scale'' - a 6'' steel ruler. Don't use a wooden ruler or a tape measure.
laser3kw
northen IL
^^^edit^^^ beat me to it! I was ********* slower than454!
use an open end wrench as go - nogo gauge.
example: a 3/8" open end wrench should fit over the threaded portion of a 3/8" bolt. Or use your adjustable wrench in the same fashion. Screw the jaw down till it just slides over the shank of the bolt, then measure that gap with your ruler.
OutsideMachinist
Norfolk, VA
example: a 3/8" open end wrench should fit over the threaded portion of a 3/8" bolt. Or use your cresten wrench in the same fashion. Screw the jaw down till it just slides over the shank of the bolt, then measure that gap with your ruler.
Just measure the thread diameter. Look up a chart/print one out buy it whatever. Look if its course or fine threads. Failing that, for sae hardware for instance, measure 1'' of the bolt and count the threads. The thread checkers/gaugers are nice too but don't help if you have to remove it still.
SAATR
Developing an eye for it takes time, but I always found just finding the wrench that fits works best. For the bicycle chain, a machinist's rule would work well.
Sent from my XT1585 using Tapatalk
readhead
Durango, Co.
Sure about that? 1/4" x 1.5=3/8. Should be 7/16. By the way the nut is the same height as the diameter. That should help to figure out length needed.
BD1
north side
mjoekingz28
Mississippi
Yes, indeed! Finding the proper wrench is my go to....but I kind of worry if I miss a size. Like say, I ink my wrench (SAE) goes like this. While it begins with 32nd size, after 11/32 it goes 3/8, 7/16, 1/2, 9/16. It leaves out 13/32, 15/32, 17/32......like that and I just wonder if I could round off a fastener . Also, I feel there could be a time when you need to 'know' what size socket/wrench you need, so you dont have to carry the toolbox with you.
I guess I was worrying about Armageddon more or less, but I think the professionals and some others may have a method that is commonplace......
JamieK
Winston-Salem, NC
csp
Franktown, CO
Your thread topic and the sentence above aren't the same thing.
Are you asking about the bolt size or the bolt head size?
mjoekingz28
Mississippi
csp, I meant I know which tool I need for threads: a thread identifier, which shows size and pitch/ for both male and female. So, yes, the sizecatcher JamieK posted appears to be perfect.
ilovevocs,
I am picking up your sarcasm, but think of this.... OutsideMachinist apparently did not make a typo. He may now know from here on the differences between course and coarse, which could possibly cause disambiguation at some point in time.
brownbagg
if its bolt head, I just look at it and pick up a wrench, nothing more is needed
OutsideMachinist
Norfolk, VA
ilovevocs,
Yes it was a mistake. I do know the difference. I also know how to measure a bolt, stud, diameter of whatever object without a gimmicky performax tool. In any case, thanks for the correction.
joecon
If you know what you are working on you can narrow down the sizes if
it is cars and trucks you can get it down two 4 sizes. Old old cars 3/8,7/16
1/2,9/16.Moderan American cars 10,13,15,18.Japanese cars 10,12,14,17.
If you want to know if it is fractional or metric look at the head if it has
lines it is fractional if it has a number it is metric.
