Anyone used StartechWeld before?
Sage55
N/A
Looking at buying a StartechWeld VHD32 kit and was curious if anyone here has heard of them or used them before and if so what are your thoughts about them?
Thanks!
sberry
Brethren, Michigan
The thing is the price or juice between the knocks and the real deal isn't always a huge leap. Not like the difference between a Snapon wrench and a HF.
Welding equipment held this for a long time but tech has now came along and increased the margin a lot. Used to be a cheap machine was still expensive in comparison but the spread had really widened as of late making the cheap a better pot odds bet than it had been. It hasn't quite matured in wire feeds probably largely due to materials cost but the little stick inverter is leading the way.
rsanter
visalia ca
Where are you located?
I have a used victor set with tanks I'm thinking I'm going to sell
Bob
Ozwelder
Mackay, Queensland.Australia
Choose a well known brand of torch with a good reputation.
Being a cheap **** when buying an Oxy Acetylene kit is not recommended.
No idea about the set you showed, but cheap bits of **** have a way of coming back and biting your **** or blowing it off ,depending on your luck.
Bondo
Greenfield, Maine
Thanks guys, I just decided to Victor instead.
Ayuh,.... You should be happy with 'em,....
Mine live in the back of my pickup, year round,...
I swap the hoses every few years due to sun rot, 'n replace the gauges as they quit workin'/ rust out,....
