Without the support of a reliable dealer, no Snap-on tool is worth the premium. That being said, they always have buy-one-get-one deals you can take advantage of. They will often bundle the metric and SAE together so you can sell the SAE sets to offset the cost.
I upgraded from a Taiwanese set, what a big improvement. As you can see below, it appears that the pin is punched into the swivel and then chromed over. Also the V shaped swivels joint binds itself at angle over 50°, if you look closely you can even see the dents. Notice how the drive end of the (WobblePlus) extension has also contributed to the binding on the middle joint? This is about 6 months of moderate shop use, the laser etching is worn, chrome has dulled, the pins are loose, the joints are stretched and the swivel is floppy.
https://scontent-yyz1-1.**.fbcdn.net/hphotos-xtf1/v/t1.0-9/fr/cp0/e15/q65/11252727_10203323018349840_9089520548354828031_n.jpg?efg=eyJpIjoibCJ9&oh=6200557ecaeda8595d49179d9a2d27a0&oe=573EA006
The Snap-on has a U shaped joint design that doesn't bind and their pins laser welded. On the same WobblePlus extension the middle portion can swivel freely. I have subjected this socket to much more use than the Taiwanese counterpart since I've also added long locking 1/4" extensions, and the socket is still like new.
https://scontent-yyz1-1.**.fbcdn.net/hphotos-xpt1/v/t1.0-9/fr/cp0/e15/q65/11391111_10203323018389841_3804977297929965353_n.jpg?efg=eyJpIjoibCJ9&oh=866fc8027ea38d0e3156284f0d3ba8d4&oe=5735BFF6
