TheEquineFencer
It's one to replace the one that got cooked when the shop burned down. The old one was "probably salvageable" for reuse if I would take the time to do a little heating and beating.
The old one I'd modified a couple of times. When I first got it, the thing came mounted to a "table" that was a 3 inch thick section of what I think was hull plating that was about 3ft square. The first time I added a long reach hydraulic cylinder I had that had the cylinder mounting pins midway of the cylinder on the sides. I was powering it with a 12V over hydraulic pump for a dump bed.
That worked great for bending 90* until I wanted to bend 180*.
Then I modified it again, I made the stand pictured below. It was complete rebuild of the system. I added the stand that has a steel pipe inside of a pipe. The bender was mounted to the inside pipe on the end, with the other end welded to another steel plate was was bolted to a wooden cargo dolly. The pipe on the outside has two chains repurposed from a forklift mast wrapped around it, these were pulled by two double acting cylinders used as single acting to rotate the pipe on the outside. The arm welded to the outer pipe would catch the end of the Hossfeld bender and swing it. For the hydraulics, I used a log splitter valve with auto detent return. The 120V electric over hydraulic pump was repurposed from an old Areoquip hose crimper.
Eventually I'll probably take the old bender apart as I need some of the tooling off it for the bare bender I just ordered and try to straighten it out some.
I ordered a set of dies for doing 1 inch OD round tubing on a 2-1/4 radius and a set for doing 1-3/4 OD tubing on a 6 inch radius for doing roll bars/cages. I did find most of the old dies, they need to get blasted and cleaned. I have a set for doing 1 inch square tubing on a 3 inch radius plus a few other odd dies. After I get the bender back operational I'll finish sorting and seeing what went missing. I think I have all the parts for doing 1/2 pipe 180*.
I enjoyed using this machine. The neatest thing it would do is bend a steel rod 90* with a sharp bend and look really nice, nothing like as if you put it in a vise and beat it with a hammer. I used it for making hooks to weld onto horse shoes for hanging brackets.
I've got a few projects that I've dreamed up that I really need to get the bender going to make. If they work like the others I've made for my long time G/F, her friends will see them and want some and I'll be back in business making stuff for our horse buddies.
I just could not see paying almost $4000 for the hydraulic attachment Hossfeld wanted and then it would have to be "ratcheted" to work. The way I did it seems to work for me pretty slick. If later I need more hydraulic power, I'll just add another cylinder. I may go ahead and move the chain brackets and use bigger cylinders when I rebuild it in a few weeks. I'm looking around for a cheap hydraulic pump and/or motor now.
