Eliminating a switched outlet?
Commendatore
Central NC
For whatever reason, my dishwasher is on a switched outlet. House was built in 2003. I can't think of a single logical reason for this. I've adapted, but once in a while someone comes along and turns it off mid cycle.
Since everything is inside a box in the wall, is it kosher to eliminate the switch, wire nut everything together and cover over the wall plate opening with something like this?
http://m.homedepot.com/p/Leviton-Blank-Insert-for-Toggle-Switch-White-R02-80700-00W/203296450
While I'm at it, I have a few ceiling fans that were wired with the light and fan motor on separate switches. I installed a remote on each that uses only one of the switches and have a heck of a time remember which switch is operational and which is useless. Is the same thing good there?
C
Commendatore
Central NC
I've never actually seen the outlet, it's presumably behind the dishwasher. There is a separate switched outlet for the disposal under the sink.
C
Commendatore
Central NC
Oh I should have mentioned, the switch in question is in the middle of a 3 gang box. Overhead lighting and the garbage disposal are on either side.
happy2rv
Huntsville, AL
In that case, yes the insert you referenced would work or you could use one of these:
You would have to move one of the switches though.
Norcal
There are fillers for switches, but you will not find them at big box stores.
wyliesdiesels
Modesto, CA
Im wondering if the DW is hardwired and someone put it on a switch to function as a disconnect so they didnt have to walk their lazy *** to the breaker panel...
info2x
Berkley, MI
Like the OP linked to or are you talking about something else?
Have you seen the outlet to the garbage disposal?
Now since you have a switch for the disposal it does take some wind out of the theory of the disposal switch.
C
Commendatore
Central NC
Yes, the disposal outlet is in plane view under the sink and it appears as normal.
I'm the third owner of this place, but it's typical cookie cutter construction. Surely it hasn't been modified by anyone and I expect the "dishwasher on a switch" situation is as originally wired. Why, I have no idea.
Zippercat
TN
Exactly that. In some communities the inspectors require those switches. OP might want to check, or at least plan on reinstalling the switch before selling the house in the future.
Whitworth
My guess is the switch was intended as a child lock-out to prevent toddlers from activating the wash cycle.
woodzy
Se Michigan
My dishwasher plugs into an outlet but if that was not the case I was informed that they wanted a switch in the event it was hard wired to the dishwasher. I think some communities have some "codes" that they think make sense. I would just take the switch out, tie the two black wires together and put a cover plate on with a blank in the one spot and not lose any sleep over it.
Norcal
If the OP is under the 2014, removal of the switch triggers the requirement that the dishwasher be GFCI protected. This does not apply to earlier NEC editions, it's new in the 2014.
