dislexiclawyer
I have finally decided on RaceDeck for my garage flooring, and plan to purchase and install around April or so. I have looked at a lot of people's threads here to get ideas for my floor, and have seen some great technical expertise. However, as I have been planning my install, I have realized there may be some tips and tricks that those who have installed this floor before can pass on, but didn't include in their build thread. I hope this thread can be a repository of knowledge.
To start, the spaces on either side of my garage door to the side walls are not equal. I have an 18' door and plan on centering 18 tiles in front of the door to make my floor pattern look cenered (similar to dubber and Rick's border pattern). This is contrary to RaceDeck's instructions about starting in an "L" shape against the walls. I was planning on starting in an "L", but along the edge of the garage door opening, and then work my way to the walls once the center section is filled in. Will this be problematic?
This means I will have roughly a 3" cut tile around the sides of the garage, instead of a 6" tile along the right half based on my garage dimensions (23' deep, 21.5' wide). I shouldn't have any issue using 1 tile to get a right and left half should I? Because of the loops and tabs on either side, I am thinking I should be able to essentially cut 6" out of the center of the tile and use the loop end to meet up with my left wall, and the tab end to meet the right wall.
I also plan to use ramp edges at the front of the garage. Is there any percentage of this ramp edge that people are having the door shut on? I am assuming I will have to lay my edges first, then my first row of tiles, then have to cut and trim tiles around the door track since the ramp edge will set the tiles back 3". How has everyone else dealt with this?
Now on to expansion. I know I need to leave an expansion gap along the walls. If I leave the tiles in the sun prior to installation, will I in turn need to leave a smaller gap? I would prefer as small of a gap as possible, but Missouri summers can still get above 100 degrees, so I need to account for that. Also, all of my benches and cabinets are along the back wall. Will an expansion gap at the back be necessary? Will the floor move with that much weight on it? There will also be less temperature change at the rear of the garage versus the front apron.
Clear as mud? I would like to know what you all think.
