d.mcfarland
Any update on the long term F80 users. Any good/bad reviews? I'm looking at getting one as my most used ratchet.
Could someone please explain to me the difference between the newer and older ratchets? Why are they called "dual" 80's?
The have an 80 tooth gear with a 14 tooth pawl. 7 teeth are engaged with the gear at all times in each direction. They're extremely smooth when comparing them the the previous generation 36 tooth models. They almost make a buzzing sound when using them fast.
Gotcha, good stuff. So do my F71's have 36 teeth then?
Dual 80 mechanism is nice.
The F80, IMO, is too short to be especially useful. FL80.
I'm looking to replace the 36 tooth Duralast that has been my trusty beater for a few years now and want to go fine tooth action.
You're 100% correct, but I'm an avid tool fanatic so that accounts for something.
Love my F80, maybe the smoothest ratchet I own, good weight, good lever, great size.
@nutsnbolts
In short: the F71 ratchet has 30 teeth while the F80 ratchet has 80 teeth. This results in a much lower ratcheting arc. "Dual 80" because it uses two instead of one pawl, which results in one pawl being fully engaged, at all times.
Take a look at this Snap-On Video, it explains it pretty well:
For the model numbers, take a look here: https://store.snapon.com/Hand-Tools-C700010.aspx You can of course find the same list for T72 (1/4") and S80A (1/2") (and other sizes Snap-On offers)
For example you find a model: SL80A (1/2" ratchet, long, standard handle) - now if you look at FL80 you'll find a 3/8" ratchet, long, standard handle and TL72 is a 1/4" ratchet, long, standard handle.
Now, I'm not going to do this for every style Snap-On offers,like I said - take a look at the lists provided on the Snap-On website, click on the different types and you will "see it".
Kind regards,
Oliver
@nutsnbolts
Kind regards,
Oliver
Too short to be useful, unless cheater pipes are your thing.What is the standard length of an F80" I am seeing one online that is 7 1/2"
For anything less than a foot long I'd look into the 1/4" Dual80s. They are mighty impressive, easily withstand 90ft-lb of torque, close to 170lb of torque on the 6.5" TL72.
170lb!!
Sent from my SM-T230NU using Tapatalk
You're assuming the person who buys an F80 only has one ratchet and no breaker bars.
It's plenty long for a lot of stuff. If not go to the long handle 3/8 or long handle 1/2.
As you can see from the following picture, the 1/4" long TL72 and flex handle TF72 are almost as long as the 3/8" standard length F80.All depends how you work!
Personally, I reckon the standard length is about perfect for the majority of jobs!
Remember that the longer the handle, the more mass you will be spinning around! Spinning off a load of small bolts with a long handle ratchet is a pain!
I really only use my long handle versions if I'm working with stiff nuts, corroded fasteners or suchlike!
Of course, the standard handle is less good for breaking fasteners loose, but I can't quite bring myself to do that with my best ratchets!
Well, since I started this thread a couple years back, thought I would at least give an update. I still have the ratchet...but honestly, I don't use it that often. The feel is great, action is smooth, but it is the most difficult of all the ratchets I own to remove sockets. I'm sure this will get better with more use, but I just can't bring myself to grab for it when I have a half dozen other ratchets that are easier to use.
Nice! Wish the price was a little lower in the used market, but people still want them at those prices.
The dual 80 is amazing, strong as can be. I put a cheater bar on one and bent the handle bad but didn't break a tooth.
That's a listing for new ones.
New is off the truck. Those are for unused ratchets on the used market.
New means Snap On knows I purchased one new so if a warranty issue occurs I can be confident I won't have a problem. Even though I don't expect to have one.
