The VISES of Garage Journal
oldldh
Fairhope, AL
Outlaw...
I take back almost everything bad, I ever said about you...
Notice I said --- Almost!!!
You are a truly magnanimous human being to try to help a fellow vise-a-holic out of a jam, like that...
Wow, I am impressed...
JZiggy
Atlanta
Picked up a clean little Reed 103 at the flea market today, $35 (seemed pretty fair to me).
I don't know the Reeds real well... would this be a 60's version?
That's not a beat working vise so...
Refinishing that little Prentis would lower its value. Carefully clean the painted surfaces. (WD-40) you can de-rust the metal surfaces, again carefully, pop the swivel lock loose (mini screw jack from inside the housing) and call it good.
You have almost 100% paint, WITH the pin-striping. leave well enough alone!
vertguy
SE WI
Nice vise and price. I have the big brother to yours (104-1/2) and think the 60's is the right era for this style.
yossarian19
People's Republik of Kalifornia
I've developed a "thing" for Reed and Athol vises, though my daily use vise is a Paramo #5. The Reed 204 I'd bought and cleaned up, I gave to a good friend. Kinda miss the vise but I'm glad I gave it away. I'll find another.
Yesterday, I "happened" to find myself at the same shop I'd found the Reed in. Walked out $108 lighter but heavier by an Athol 624. The main screw is a little worn, racks slightly at fully open, but pretty good shape overall and plenty of life left in it.
4" jaw, 6 1/4" open with full threads, three bolt base with a cogged swivel (single handle). It weighs 59 lbs, not bad for a 4" vise.
I've cleaned it with a wire brush, steel wool & WD 40 and put it back together. Unsure if I want to paint it or leave it as is.
Bob!
joshua tx
That's a twin to the one I have mounted on my garage bench. I wouldn't part with it for $7 even if it hadn't been my Grandfathers. Congratulations on a good find. Are you planning on spiffing it up before you use it or just giving it a quick lube? Welcome to the thread. If you do make it all shiny and new looking take lots of pictures.
yes sir,i would like to clean it up and paint before mounting.
i also went back and bought another vise for $7 i'll post a pic in a few
topop101
NW Missouri
Digging around in a small town True Value hardware store and came across there user vise . This is the biggest Babco I've ever seen. 8" and in minty condition. They said it has been there at least 30 years. That was how long the guy working there has been there. He said it looked old when he got there. It was a cool old building and had a big walk-in safe they use for storage.
I offered to trade them a 5" Wilton bullet vise and they laughed..
PoorOwner
CA
That's a sweet vise.. Made in Oakland CA? Hmm
I wouldn't trade it for some wilton either if I had used it for 30 years
rockscout
Located in Bosque farms new Mexico
Hi y'all I've been lurking and learning for a while figured this is the place to share and ask what my options are. I just broke my rock island 574 vise. Was clamping down and the threaded screw snapped. I wasn't banging on it or anything like that just putting some weight into it. Blew my mind since I've never had this happen. I'm thinking of welding it back together but figured I'd ask if there are any other options before I tart burning metal.
Jim Johnstone
Brantford, Ontario
Have a machine shop make a new one? Personally I'd go that route before welding it back together.
Sent from my SM-G900W8 using Tapatalk
Babco's were considered decent if not very heavy duty vises back in the day. These days they are imported from you-know-where...
CwazyWabbit
Surrey, UK
Post a picture of the broken screw so we know where it's broken.
zkling
They were foolish on that me thinks, but as long as it works for them. Pretty sure that was made in china, should be marked on the side of the dynamic jaw. Can't read it from the pics. They are a nice heavy vise for a stamped slide unit though. Here's one I did a while back just for the hell of it.
drivesitfar
Rockscout: can you post up more pictures of your vise? if the screw is the only thing broken maybe you can put a post in the vise parts thread asking for a replacement that somebody might own from a Rock Island vise of the same model that has something else broken.
http://www.garagejournal.com/forum/showthread.php?t=88292&highlight=vise+parts
also welcome to the forum
Top: thanks for old safe picture and you can also post that and any other old pictures on the OLD PICTURES thread i started in vintage tools that is getting some nice pictures. i'm curious about Babco's history because i thought they were all imported from either Taiwan or China. that one you posted does have some nice lines and it looks pretty stout so understand you liking it.
VA: YES, Reed is probably my favorite, but others are not far behind
Yoss: nice looking Athol and i vote BLO
mroneeyedboh
What do you all use for grease on a wilton? I'd assume to use something like a grease? Can you lightly heat the metal to allow it to creep and get into the pores better?
topop101
NW Missouri
Yeah . I restored a pair for a farmer . They were 6"ers. Darn heavy ! That's why I was :drool: over this 8"er. I may have to return there with a Wilton in hand. It might make a difference :dunno: worth a shot in my mind... Wiltons are a dime a dozen ... 8" Babco's ...not so much
ZK, the older Babco's WERE made in the USA, in Oakland CA. Current Babco vises are imported. They look about the same so I'd guess the tooling/factory was shipped overseas,
You could, but I doubt it will actually penetrate much if at all. What it WILL do is to get any moisture out, so their is less chance of rust forming under the grease.
drivesitfar
TJ: i've saved another BRIGHT GREEN vise of yours to my laptop. are you going blind doing those or do you just wear sunglasses?
amazing work and painting skills :thumbup:
CwazyWabbit
Surrey, UK
If the section where the break is doesn't ever screw into the main nut I'd give welding that a go, if nothing else it would get you going again till you could find a replacement.
The threads in the area of the break will probably have stretched so if that section does go into the main nut I doubt you'd be able to get it to work smoothly again.
If you do decide to weld it then taper the break so you can weld it in multiple passes and get the full thickness welded.
Pay particular attention to keeping it straight (apologies if I'm teaching you to **** eggs)
EDIT: another option if the break is actually in the nut area would be to chop some off the handle section of the screw, this will of course mean you end up with a shorter screw and perhaps not the full opening ability of the vise..... but it would mean you may be able to use the vise again.
zkling
I never said they weren't Drivesitfar is the one that said that. The dynamic jaw on the vise top posted clearly had COO cast into the front of it. Can't make it out in the pics, but to me it looks longer than 3 letters. :see:
Shiftless
East Bay SFO
Regarding the Babco vises:
After checking information on Dayid's page it looks line the Babco vises marked "Oakland CA 94621" like the one in question were made in Japan. Later ones not marked Oakland I suppose would have been made in China.
Babcos pre dating the one in question (also from Japan) were marked Oakland 14 which was the postal zone for Oakland prior to national zip codes being enacted in 1963.
94621 is the current zip code for that area of Oakland.
Although I live only a few miles from Oakland, CA I have never seen a Babco vise marked Oakland at a local sale. Just the later inferior models.
:dunno: Look again; I'm pretty sure that is U.S.A.
Shiftless
East Bay SFO
Outlaw:
Oakland CA is certainly in the USA but after a little research it seems as though that company put its office location on the vises even though they were cast in Japan. Deceitful? of course!
KMScott
CW, I might add that if you chuck the spindle up in a lathe and say ream a hole for a press fit 3/8 x 2" dowel pin on both broken half's. This does two things, first it aligns the spindles half's and also gives a little more strength before welding. But the handle might have to be removed depending how you drill and ream the hole's. I would also suggest welding with a strong type rod and giving both sides a healthy chamfer. If I was doing the repair then I would use 680 Eutectic rod with my TIG welder since this rod has 140,000 tensile strength and a little less on the shear strength.
Rockscout, if you are looking for a replacement then it would be a good idea to know what kind of threads you have (Square, Acme or Buttress threads) and the diameter along with the pitch.
