The "Bunker" garage is almost complete!
U
utah997
Sorry I've been a little absent here lately guys.
Progress is still happening in the bunker section. We are just working on completing the bookcase door to the tunnel.
Whaddya think?
Originally I was planning on having a bookcase door, basically just a bookcase on door hinges. I finally calling my carpenter and we got looking at it. The problem was, the opening was just to big to have it swing out and look good. So I suggested a pocket door.
Soo....
I DID have this room all sheetrocked and painted. But in order to do this, I tore out the one wall, and had it re-framed out to hold the bookcase
Closeup of where we will be mounting all the hardware
So the basic idea was, to mount garage door tracking along the top of the concrete wall, then put a 2x4 mounted to a header along the other side. Once we had the track mounted, he took measurements and starded building the bookcase. In the pic below, you can see all the bolts used to mount the wheels to the top of the bookcase. It's some serious hardware... :smash:
Being delivered
Mounting it took a couple of hours of monkeying around with stuff.
Success!
Took quite a bit of adjusting to get it to close right. We used a gate opening motor. Which is ok.. I was under the impression that it had adjustable speeds, but it turned out that it didn't. So even after the adjusting, it still rocks a little as it opens. But I'm hoping after the final trim work is done that it will tighten up..
Drywall on..
Jay
awesome! I bet it will not rock as much when you have "books" on it.
TAMPAGT07
Palm Harbor, Fl
Hey Utah997...If you want that bookcase to be supercool, you need to get a bust (like in the original Batman series) with the switch inside the bust, to activate it the door. :bowdown:
Striker
I was following this build over at AVS when Utah started it. Simply brilliant. Nice touch on the door. :)
RobSmith
NSW Australia
How about a track along the bottom of the door. Not on the floor but under the book shelf and back into the cavity. like those extendable drawers...a telescoping track to stabilise the cabinet on its' travel.
Just a thought.
U
utah997
Just a thought.
Not a bad idea.. we'll see how it does when weighted down, and once all the alder trim is all snug up against it.
N8
In a house
This is a great build. You have some great ideas.
Almost makes me miss living there seeing all the photos of the mountains.
DOACanada
Cambridge, Ontario
Utah,
Have you thought about putting the bottom of the bookcase on a track? It would probably help reduce the amount of "wobble" back and forth that you were talking about.
This is an amazing story and certainly is great to follow. Thank you updating.
Todd.Brock
Cincinnati
Your whole set up is what kids dream of... Now, a legit question. I was looking at the beams they set into the "pockets" of the concrete wall to set up for the second floor. What set up did they use to pour concrete over the steel beams?
chinoanoah
Wow just found this. very very very very very very very very very cool!
Can I criticize? The diamond plating, everywhere, is tacky... And to be less critical and more curious, a Porsche, Ferrari, ...so why the Vette?
Plz keep posting, we love seeing it!
thomask
Sunshine State
:bowdown:I have been through many post here and really think this one is one of the Super Builds.
By any chance had you seen pictures of the garage in a Beverly Hills backyard built underground so the backyard could be saved? The plants, trees and grass were all saved and replaced when the garage was completed. Full of expensive antique cars.
Love the build and pictures, thanks for sharing. Nice VET.:)
U
utah997
Thanks for the compliments. As for the diamond plate, I was going for the clean modern look, I really like it - It's one of my favorite parts of the garage. (but to each their own)
As for the Vette, I had it before I had the other two. It has an STS twin turbo system on it, it's an absolute blast to drive. Try one.. you'll like it!
rieferman
Collegeville PA (30 min west of Philly)
I don't agree with the tacky comment at all. In my opinion, it's very thematic and appropriate given the setting and how you sparingly applied the diamond plating. Like you said, to each their own, but I agree with your taste on this one.
GX624
1) Why even make a post like this, dude?
2) Learn a little something about Vettes and you wouldn't think about asking that question.
3) Two words.
Blstr88
NH
Hey, just joined this site and was looking around and saw this...did you post these pictures on dodgetruckworld.com too? This looks super familiar...
Crow11
Take a look at replacing the garage door track/rollers with linear pillow block system the bearing will run about 100 a piece ant the rail about 40. This will give you a very smooth movement.
thetastelingers
Soddy Daisy
A sliding bookcase......Rediculous!
We are about to build a house and for the life of me, I can't find a place to put a secret passage.....grrrrrr.....
walperstyle
Wish I had pictures of my friends parents house. The hidden room they had just looked like part of the wall, but behind the light switch, was the door knob.
U
utah997
Nice!
Link to buy?
chaingang
B'ville Ga
Nice!
Link to buy?
McMaster Carr has a good selection of linear bearings and even small servo's or linear actuators that might do the trick. A DC servo and drive would allow you to control the speed. They have engineered drawings for most items. You should be able to find something that will be better than the rollers.
PS. Way Cool. :beer:
mybigwarwagon
Vale, Nc
Wow. I just joined because of this thread. Although it makes my two 10x12 buildings with a tarp between them look like ****. Oh wait a minute... they looked like **** before.
This garage is truly amazing. One thing I was wondering though. Did you put a hidden door on the house side of the tunnel. Then i would be truly a secret hiding place.
