After reading and rereading many great posts on here about lifts, I decided to go with a C-7000 lift. I liked the Maxjax but I wanted higher lift and safety stops.
I am in the middle of installing the lift. I drilled a couple of holes to 4" deep with a Bosch 1" bit that has two full-size cutters and two smaller cutters. You are supposed to tap the included Powers Smart DI+ anchors into the holes and then use the set tool. My anchors fall to the bottom of the holes. There is no initial friction fit. I checked the hole sizes and they measure from 1" to 1-1/16" in diameter. Does anyone know if it's ok to set the anchors with the set tool as is or am I screwed on hole size?
Thanks,
Steve
Thanks,
Steve
