General Geoff
On the back of a bottle of CLR, it specifically states NOT to use it on copper. However, I just successfully used it to very quickly and easily strip some heavy gauge stranded wire used for a truck battery terminal (broke the original terminal when trying to take it off the batt post, it was just too brittle in ~5 degree weather!). Unscrewed what was left of the old terminal, and just dipped the frayed wire end into a small glass of CLR for a minute. Watched as the copper went from nasty green/black corrosion, to shiny and clean. Took it out, dipped in a glass of water to get any residual acid off, then slathered in dielectric grease before clamping a new terminal end on. Very strong electrical connection.
Thought I'd pass along the tip to anyone who needs to replace a terminal but doesn't have the slack to cut off the ratty ends of the wire.
