New House, New Garage
nefkntym
Colorado
Well maybe not new, but new to us and a chance to do things again and better. I have been lurking here for a while, just gathering information and such. For a few years, I had been entertaining the idea of doing epoxy. I am glad that I didn't do it because we don't have that house anymore. We moved into our new house this past June. There was a need to move quickly because we hadn't sold the other house yet. That coupled with the RaceDeck Father's Day sale presented me with a scenario that was too good to pass up.
Pics of the garage from when we were under contract to buy the house. Actually, the day we had the inspection done on the house.
It all starts with an idea.
Before I unloaded it, I decided to fire up the drone and get a couple pics of the house from above.
Getting started
Finished with the flooring and ripped out the old door openers. I replaced them with some new craftsman quiet drive units.
With the flooring done, it is time to bring over the other two cars and the rest of the stuff from the old garage. Time to start thinking about storage as well.
One of the changes that I made during ordering was that I wanted the solid diamond tiles for the front of the garage in the work area and everything if behind that would be free flow.
One of first things to get setup after bringing everything over was the compressor and reel (tired of hitting it and it helps with cleaning). I picked up some decent 8" pine from Home Depot and some fairly long Spax Torx screws as well. I got the idea from someone on here was doing a garage and putting up a French cleat system. I think it worked out pretty well, it has been up for almost 8 months now and it's still solid. A lot better than before at the old garage with 2"x4"s and some extra lag bolts that I had lying around.
After getting everything put into its place, throwing away garbage and cleaning, the next project that I tackled in the garage was storage. I made some half-*** shelves at the other house and I also had the luxury of a shed as well for the bikes and anything else that got stuffed in there. At around this time I got an email from Costco, one of the things for sale was the Safe Racks. I picked up a double 4'x8' set for a pretty good deal and got to work when they arrived.
They gave me a great option for storing the bikes as well.
At this point, I was more than ready to get back to work on my car project...until I truly realized how abysmal the lighting in the garage was. To add insult to injury, 1 of the 2 light fixtures gave up the ghost as well. Down to 1 light, that just won't do.
On the way home from work the next day, I decided to stop by Home Depot and pick up 5 twin light fixtures, a bunch of the new Phillips LED bulbs, a roll of Romex, some outlets and single gang boxes. This time around, I wanted everything to be as clean as possible. I decided to tie into the existing circuit for the overhead garage lights to keep it simple.
Light install finally done. I took this picture around midnight, no flash, garage door and curtains closed. It was just the overhead lighting. Not bad, not bad...
Time to reinstall the lift. Prior to this point, I swapped out the tiles under the lift plates to diamond tiles. I figured they would take the weight better than the free flow tiles :) I drilled the holes directly through the RaceDeck tiles into the concrete. I also decided to use Epoxy this time with the anchor install. The anchor install was great, no spalling or cracking of the concrete under the tiles after almost of week of curing.
Time to install the pillars
Those steps. They needed some covering.
Getting closer
At this point in time, I was finishing up the welding on my exhaust. I wanted to be able to lift the car to full height with the door open but that was not going to happen because my roof box was using my car for storage.
It was time to do something about that other than just putting it on the ground temporarily when I needed to use the lift.
More recently, I had to do something about my most commonly used power tools, computer for connecting to the car, batteries, chargers, etc...
The next thing I want to do other than some serious organization is to install a heater. The unit that I have been looking at is a SpaceRay CB-50. The plan is to hang it in the open space above the TV at a 45* angle.
Right now, the most difficult thing seems to be getting a quote for running the gas line. It's February, so I figure I will just leave it as a summer project to be used for next winter.
Well, this is my garage. I have learned a lot from this forum and it has helped tremendously in getting me to this point. I look forward to learning more and like most others, transforming my garage into something that has both great form and even better function.
N
nefkntym
Colorado
^^^Thanks!!
Well, I went to the store to get bolts to put my engine on an engine stand and I decided to pick up some Husky cabinets while I was there as well. Garage organization is a serious thing :)
Engine on stand
1 of 2
A big one to go by the door.
First one assembled, the other one will be on the other side and I will stack the wheels on top of it.
On a different note, I busted out some of the flooring to clean it up. Its been 7 months, looks so much better now.
N
nefkntym
Colorado
Thanks!! I am really loving your garage as well. I wish I had your heater!! I plan on installing the same unit this summer so I will have it for next winter.
55cadillacking
Calgary
Yeah, the heater is sublime. How's the SQ5 treating you? Haven't seen a Volcano Red in the flesh. Looks great.
dislexiclawyer
Missouri
Your place looks great. I am eager to see what else you do to further organize the space. Your stair tread is an interesting idea. How did you attach the RD tiles, and what is on the edges of the tread?
N
nefkntym
Colorado
I can't wait to get the heater, it has been so cold lately. Not that you don't know anything about cold though. I love the SQ5, the Volcano Red is amazing! However, that is my wife's car. I had an '15 S3 Prestige and traded that in July for my '15.5 V60 RD.
As for the SQ, it is her car and it is kind of scaring the **** out of her driving it in snowy and icy conditions because of the power. She is looking at trading for an 2016 Q3 Prestige S-Line, she wants something with less power, smaller and less thirsty as well. It is her car and her choice, we shall see.
Thanks, it is process that I have been happy to undertake. I am looking forward to more organization too. I screwed the tiles to the steps and the edges were wrapped and stapled with weed fabric. One day, I will the take the whole thing apart and paint it and the reattach the RD tiles.
James-W
Southeastern Wisconsin
I really like the way the garage looks. I am like you in that I had thought about epoxy on the garage floor. In some ways I wish I had an epoxy floor, but the time and the effort it takes to do the prep work is just too much for an old fart like me. I put down Racedeck and I really like it, but I chose the diamond instead of the Freeflow. I do mostly woodworking and I figured it would be easier to sweep the floor with a solid tile.
dubber
Canada's Capital
RaceDeck, German vehicles and Husky products..... My kind of space! Kudos.
Edit: Awesome selections of vehicles. How did you like the S3, didn't have it for long it seems.
bczygan
DETROIT! Arsenal of Scrappers
Nice looking garage.
But that floor makes me dizzy.
And having to remove and power wash it???
I spilled a gallon of used oil on my garage floor.
That's the finish I'm going with.
Bill
N
nefkntym
Colorado
I was looking at the Epoxycoat systems pretty hard. I am really glad that I did the Racedeck. I do all my wrenching, wiring and welding in my garage, that is why I put the diamond tiles in the back for the work area and left the FF for the cars. One thing I do love about the Racedeck over the concrete and epoxy is how much warmer it is when you lay on it in the winter and how much easier it is on your joints.
Thanks!! Now it is two Germans and a Swede ;)
I loved the S3, I would be lying if I said I didn't miss it. I did want something bigger with more everyday usability. Having said that, I love my V60 RD. Best car I ever had and that includes a list of 3 S4's, 3 A4's, an A3, an S3, a Q5 and an SQ5. I think Volvo is very underrated.
Bill
Thanks!! It did the same to us at first, after a few hours, it wasn't an issue. You don't have to power wash it. Just like some people would powerwash, sweep, maybe mop or do nothing at all to their regular or epoxied floor. One thing they can't do it removed their floor to clean it.
I choose to remove and powerwash because it is so easy, so lazy, pretty therapeutic and because I can ;)
James-W
I have noticed a difference in laying on the Racedeck floor tiles rather than on the concrete as well, although I don't do all that much car work anymore so I don't lay on the floor much these days. Walking on the tiles is sure nicer than walking on the concrete, my feet don't get as cold.
I have a Hot Dawg heater that I run all Winter long to keep the garage temperature at 50 degrees unless I am working out there and then I turn it up to 70 degrees. Since the fins on the heater are angled downward the heat blows toward the floor so that helps to keep the floor warmer too.
N
nefkntym
Colorado
Well, you're certainly not in Wapakoneta OH like your Uhaul said!
Looks like a great house and space!
We really do love our house. Here are 2 more pics from a different perspective.
After making good use of the snowblower my wife bought me as a gift.
I lit the big tree to side of the driveway with 6000k led lights. I love my Christmas tree, didn't really love putting up the lights though.
View from the balcony.The whole back wall of the house upstairs is windows (except the Master bedroom), this is the view from inside as well.
N
nefkntym
Colorado
I don't lay on the floor to much either since I have the lift, but there is always some reason that pops up from time to time. I cant wait to put to heat in the garage. That will be great!
Ultrasport? Or you just add the goodies?
Not an Ultrasport, the car is an 2003. I have the Ultrasport front bumper but the sideskirts and rear bumper are S4. It has a B7 S4 Recaro interior with a 2013+ partial air leather flat bottom steering wheel and a latest gen Euro RNSE navigation. I have to bits to retrofit the factory bluetooth and sat radio as well. I am going to start pulling out the VR6 and I am going to go back to a 2.7T.
James-W
You sure have a wonderful view from your house. The wife and I went to Colorado several years ago, we were at Snow Mountain Ranch (YMCA of the Rockies) for a week during the Summer months and we had a wonderful time. We have talked about going back again, but we aren't as young as we were when we went the first time so maybe we wouldn't have as much fun.
N
nefkntym
Colorado
What a beautiful place. I bet there are some good riding trails to put those bikes to good use in that area.
Thanks, there are actually quite a few trails here in the area to put the bikes to good use.
Thank you, the view was a big deciding factor for the house. With over 3.5 years of looking off and on, this is the first house that we agreed on. The company that I work for does an annual retreat for employees and family to Snow Mountain Ranch, it is actually coming up in about a month or so.
I'm assuming you frequent www.swedespeed.com?
I do.
N
nefkntym
Colorado
Since I picked up the cabinets from Home Depot.
I got the table on Monday and the Stools showed up today. The stools are classic soda fountain style, they swivel and adjust in height as well :) I am pretty happy with them so far especially since they are red.
I swung by Home Depot today after work to get more cabinets. They are all gone, the associate I talked to thinks they are being discontinued. That really ***** if that is true.
Blixem
Great garage and awesome selection of vehicles.
I LOVE the B6 Avant with the turbo VR6 swap. Do you have a link to a thread with more information/ power output/ effort etc?
dubber
Canada's Capital
Looking good in there. Have you considered painting the trim of the two doors and stair rail? That would tie everything in really well.
hack-man162
Nice place nefkntym! Looks like Gods Country there!
re: Volvo V60 RD versus Audi S3/S4
So I should lean towards the V60 Polestar? I am a Volvo fan from way back, but was wondering what peoples real-world experiences are that have owned both (or similar).
Purist
MAsshole
So far, so good. I'm liking what you've done with the space available to you. Sick view from your balcony, too. Would love to visit Colorado some day.
Keep up the good work! Oh and I second what dubber said, you can't beat those German cars.
N
nefkntym
Colorado
Thanks, I am really enjoying this space. The last garage was a 3 car plus tandem in the center to park a 4th car. This garage even though it is a 3 car, is bigger by over a 100 sq ft.
:beer: Fun watching someone else progress through their garage journey. Kinda miss the process.
I bet, I am enjoying working on the garage. It is time for you to do a redesign. :thumbup:
N
nefkntym
Colorado
From earlier :)
Working hard at hardly working...extracting oil from a pulled engine, sitting on a barstool drinking coffee while watching the morning business channel in the garage.
