new to the forums but have been reading threads here for a while.
I recently bought a old sears 2 ton floor jack model # 328.12040 made in japan. the jack will lift up a car fine but will leak down in about 3 minutes. I have read just about every thread hiball has made concerning floor jacks but I am still stumped.
I assumed the jack was leaking through either the check valves one big steel ball with a little steel ball under it or through the release valve. I pulled all 3 balls out and inspected the balls and its seat pretty close and could not find anything wrong with either. the overload was set 1 turn out ( well within spec from what I have read).
my question is can fluid be leaking past the main ram seal without leaking fluid outside the ram and onto the floor?
thanks for any help you can give me!
