What are the Popular Knipex Tools?
winlinmac
USA
In addition to Cobra / Alligator Pliers and Wrench Pliers, what are some of the other known popular Knipex Hand Tools which I should consider adding to the toolbox?
Sure, I would own them all, but for a starter kit and someone on a budget, what else should I add? Sears stocks a lot locally and at their warehouses. :)
W
winlinmac
USA
Haha, thanks d.mcfarland, I'm trying to go through all the relevant threads, but was hoping to consolidate them into one here (similar to someone's thread regarding essential Channellock pliers). :)
Reading more should help on this topic.
rshadd
Doylestown, PA
The Knipex Mini Bolt Cutter is a must have.
Krause
This just came up in another thread, but if you need Circlip/Snap Ring Pliers then their Precision line is probably the best around.
[edit]
I second that one too.
W
winlinmac
USA
Awesome, thanks, so far we have on this thread---
- Insulation Pliers
- Pliers Wrench
- Mini-Bolt Cutters
- Cobra Pliers
- Circlip / Snap-ring Pliers
Looking forward to hearing more
Krause
- Insulation Pliers
- Pliers Wrench
- Mini-Bolt Cutters
- Cobra Pliers
Are you trying to decide what from Knipex is the best/stands out above other German/US tool companies specifically, or have you decided on Knipex for the bulk of your tools (that they make) and are just looking for a list of things you should have in your box?
If its the latter you definitely will need side cutters, chain nose (and possibly needle nose) pliers, linesman/combination pliers. I don't know if I would say they are the best, but if they aren't, they definitely are up there.
Oh and I'm not really a fan of using adjustable wrenches, but if your looking for one Knipex makes probably one of the coolest designed one I've ever seen.
kctyphoon
Jersey/Staten Island
I have the 8" and 10" diagonal cutters, 10" alligators, lineman pliers, and the mini bolt cutters. They are my most used hand tools and the best ones I own.. I'd say anything from knipex is worth the money if you have a legitimate need for them.
mrjaw14
Nashville, TN
Mini bolt cutters, linemans pliers, needle nose pliers, alligator and cobra pliers, pliers wrench...pretty much anything with knipex on it lol. Quality is amazing
mattwhite079
Western Australia
I recently bought two multi grips that's have an extra link to keep the jaws parallel. Replaces a shifter I guess. But better because you can keep it tighter by squeezing the handle. Absolutely love them. Love knipex in general tbh
Gotcha640
Houston TX
I'm always a little confused by these threads. Have you ever been in need of tiny bolt cutters? No? Then that recommendation is probably not worth much. Yes? Then you already have a pair, and if you're a knipex fan, you already have them.
Maybe the people who start these threads have more money than I do (not difficult, with student loans and kids and maxed out retirement contributions) and just want a full tool box?
W
winlinmac
USA
Well, lately I've been assessing my tool purchases over the years. I get what I pay for. Anything cheap, I get cheap in return, its too true and I learned to appreciate that along the way. :)
Are there any deals on 1,000V Insulated Diagonal Cutters?
bmwpowere36m3
OP,
What tools are you looking for, specifically? Or are you just asking what's worth getting from Knipex... the list is endless, can never have too many tools ;)
What do you need? What do you use them for?
I've never had a need for mini bolt cutters... full-size, sure. If I need to cut something I just reach for my electric or pneumatic cut-off.
bmwpowere36m3
Must be tax-refund season... :lol_hitti
rodsnratfinks
California
I figured this thread was good pointing out what to spring for Knipex specifically for.
Here's some things:
74 01 200 8" diagonal cutter -these have very good leverage and cut well. I might eventually get the 10" one for thicker stuff, but these are great all around cutters.
38 11 200 8" snipe nose (sometimes incorrectly called needlenose) - these are the best mechanic snipe nose pliers I've seen. No annoying cutter makes for good fitting and stiff jaws that mate perfectly at the tips. Also, amazing gripping ability, and the handle fits my hand well, but the pivot is really close to the handle so you barely have to move it to open the jaws wide. Great design.
As you can see from my pliers drawer, these are what covers most of my needs for the wide variety of things that I work on. My next Knipex purchases will likely be duckbills (38 41 190) and bent nose pliers (38 21 200). After that, I will probably get 8" square (28 01 200) and snipe (28 21 200) nose assembly pliers to replace the ones seen on the right in the photo. That would easily cover nearly all mechanic needs. My long reach pliers are Mac and will probably stay that way, since any time you use a long reach plier, you are already compromising precision; it just doesn't make sense to buy these from a precision brand.
I also plan on buying Knipex or Engineer (Japanese brand) mini pliers to replace my craftsman and Mac ones. The Mac variant are okay, but the precision could be better, and do a lot of electronics work, so I think I deserve it. When I do, I'll be getting ~4" snipe, bent nose, 5" needlenose, and maybe a flush cutter for soldering. This would replace most everything left of center in the photo.
I also have Knipex 92 28 69 ESD fine point tweezers. These are wonderful to have around and do a good job at everything you would use tweezers. Just a note: get a least one good non serrated tweezer. I like Knipex, Wiha, etc. Anything German or Swiss. There are fancier brands, but those two when found on sale are great. Try Zoro.
PureLeaf
How are these?
spin_prod_220873101
I have those, and their universal jaw style. Work fine.. I've got some old USA Vise Grips, and some brand new style craftsman chinese ones. The craftsman are ****, but I'd say the knipex and my old USA ones are on the same level.
Jeremy77
Coastal Alabama
How are these?
spin_prod_220873101
I own 2 pairs of these as well as the 7" long nose locking pliers and they work very well. They are a bit pricey compared to many other options out there but the quality is there and I'd not hesitate to purchase more if I needed them. It'd be nice if there were a U.S. made brand of locking pliers but shy of finding some NOS, these are one of the best options out there.
jallyn
Fort Wayne, Indiana
You guys with the Knipex locking pliers (vise grips). Have you tried Grip-On brand from Spain? If so, what do you recommend? I have just cheap Chinese Vise Grips and will someday upgrade. Curious what you think...
W
winlinmac
USA
I've read some reviews stressing on the rivets on the Knipex Locking Pliers. They're not as popular as some Knipex's other offerings.
It's really important to have a variety of different sizes for that one tool. I like Knipex's adjustable features.
W
winlinmac
USA
I'm speechless by the goodies I received in the mail today. I think I should phase out on Channellock and Wilde, and be a Knipex Tool Junkie. What do you all think? :D
The handles just feel right in my hand.
kctyphoon
Here's some things:
Are the long reach pliers you have Mac Tools branded, or from the Amazon deal I posted in hot deals forum?
W
winlinmac
USA
How are the Comfort Grips? Are they similar to Channellock's Code Blue? I've always felt that these hefty grips come in the way when it comes to working in tight quarters.
W
winlinmac
USA
Talking Knipex Cobra's, does anyone here own the insulated type? Are they really useful in electrical work (i.e. placement of electrical conduit, grounding, etc.)?
spin_prod_606114501
Milwookie
What often happens with me is that I need a tool I don't have to finish a job I've started. But since I'm partway through the job and need to get it done, I end up at Home Depot getting whatever they have that looks like it will work for what I need. I've ended up with a number of tools that were OK, but not great.
Now I'm looking at tools going "man, I wish I'd had those in the past!" and putting them in my toolbox for next time. The Knipex bolt cutters fall easily into that category. Sure I could use my Dremel, but clippers would be way more convenient. And while bolt cutters may seem like overkill, I imagine they'll cut everything the nippers will and more. So for a few dollars extra I can maybe avoid someday having to get two tools when one will suffice.
RichWentFishing
I highly suggest getting the angled mini bolt cutters and angled 10" diagonals. The straight ones are nice but having that angle is so much more convenient for flusher cutting and prying.
In my neighborhood the trash guys won't take any wood that has nails sticking out of it. It's faster for my to just pop them off with the bolt cutters than to rip them out.
