Mobile Brake Drum Grinder Stand
flyingblind
Washington
I needed a grinder stand that was mobile, somewhat inexpensive and heavy enough to support a grinder and a buffer. The buffer details have not been worked out yet and I work a lot so here is what is done so far.
I used a semi brake drum and a semi trailer landing gear leg. They were free from the shop that fixes my Pete. 70 dollars in wheels and bolts.
Brake drum
WP_20160206_003 by Al Capone, on Flickr
The foot off the semi-trailer landing gear is bowl shaped so I sawed every hole in order to pull it flat using the drum. I located one hole and then used cad to plot out the other hole locations and then used my mill.
WP_20160207_001 by Al Capone, on Flickr
A slug from the foot
3xWP_20160212_007 by Al Capone, on Flickr
Pulled the foot all flat using the impact gun.
5WP_20160212_005 by Al Capone, on Flickr
Test fitting the leg and base
6WP_20160207_003 by Al Capone, on Flickr
F
flyingblind
Washington
F
flyingblind
Washington
I made a base for the wheels
WP_20160221_003 by Al Capone, on Flickr
WP_20160221_009 by Al Capone, on Flickr
This dog bone fits through the slots in the landing gear and one bolt binds the wheels to it.
WP_20160221_013 by Al Capone, on Flickr
You can see the slots for the bone and the leg at full extension which this will probably be the very last time it will ever be extended that far.
WP_20160221_011 by Al Capone, on Flickr
Wheels installed and retracted.
WP_20160221_014 by Al Capone, on Flickr
all for now
Whiskeymike
Austin, TX
I like what you've done! I have the same drum waiting to be built out. I wish I could find a similar landing gear leg. Wonder if a jack stand for a trailer would work.
Subscribed, looking forward to seeing the rest!
F
flyingblind
Washington
Thanks all.
I ended up with most of today off so I cleaned off the rust and started the layout for the top plate. I plan on mounting 2 pieces of angle iron and then bolting this to the landing gear leg for access to the top gears, so in the future if I want to add a motor to raise and lower it I can. (probably dreaming :rocker:)
This scrap cost me 10 dollars so now my total is 80.00
15" by 8" by 1/2" and I think it will be long enough to mount a grinder and buffer barely.
WP_20160222_003 by Al Capone, on Flickr
MJD1
Looks good and a great idea. By coincidence I am changing out a set of landing gear tommorow.
MJD1
If you build one too that would be very cool. But if I had two I would use them to lift a heavy fab table.
I have access to several sets of older ones, often they just crank hard or the lower leg gets bent up. I always wanted to use one for a mailbox post. Whenever the mailman complains about the height, it could be set to whatever suits them at that time.
F
flyingblind
Washington
The mailbox would be cool, you could leave the crank arm hanging. Too funny
F
flyingblind
Washington
Here is the bottom view of the top plate. I plan on using 5.75x3" bread loaf pans for water that will mount to the bottom of this plate, not sure how yet.
Just need to drill out the holes in the landing gear to accept this, some clean up then paint to finish. It will hold 2 grinders (one with wire wheels) instead of a buffer grinder combo.
WP_20160304_001 by Al Capone, on Flickr
F
flyingblind
Washington
That's a great idea. I esp. like the casters!
Thanks. I put some thought into the casters but in the end I just settled for the cheap Lowes 2" casters. I originally wanted the skate/blade casters, but at 12 bucks each for something that will never be seen it was a no go. My total is about 95 dollars now with some added scrap and a few more bolts.
F
flyingblind
Washington
Very nice! How well does it roll? Need to see a video of you cranking the wheels down and rolling it around.
Thank you. It is very heavy and rolls great but it doesn't like going over anything 1/2 in or better. You kinda have to wobble it over big bumps or shove it with your foot. As for cranking, it takes about 4 full rotations to get it to a good height for moving but I think it will just sit in one spot and the wheels will be used mostly to rotate it around for the other grinder.
