I need a foundation fix.
Zombifyd925
Saratoga County, NY
Hello, it was such a nice day yesterday, I went out into the garage to do some work and when I went to close the side door I noticed the whole wall shift around. After investigating, I noticed a few cinder blocks became detached from the slab and now move with the wall as I move the door. How do I fix that?Hello!
Spunka1 shared a video with you.
View Video, http://s41.photobucket.com/user/Spunka1/media/VID_20160228_121619280_zpssj7ugyrn.mp4.html
Bondo
Greenfield, Maine
Ayuh,..... My guess is the frost has heaved the buildin', somewhere other than where ya took the video,...
In another month or 2, it'll fix itself,....
Cyberbear
California
Unfortunately, this is not uncommon with cinder block construction that was not properly reinforced when installed, especially near door openings that receive constant hammering when the door is closed. If this were mine I would remove the loose pieces, drill some steel rebar into the slab below and after re-grouting the blocks back in place, then fill the cores solid.
theoldwizard1
SE MI
Yep. Go to keep the water away on the outside. French drain.
Once it settles down, rent a SDS drill and drill all the way through from the top, deep into slab/foundation. Clear the hole of dust and debris. Partially fill the hole with "setting" epoxy/concrete and insert a bolt. You could also use an expanding, anchor fastener at the bottom, but it had better be stainless.
At a minimum the bolt should be hot dipped galvanized. Stainless would be better.
Kevin54
MEMBER EMERITUS
Urbana, Ohio
^^^^THIS^^^^
They rent concrete bits that are up to 24" in my area. Finding an anchor might be a little problematic, but you could always epoxy in all thread then tighten it down. If it were me, I would put in two anchors on the first block, and at least one anchor on the next black just to make sure the blocks are down solid.
NOW......you may also want to spend some coin and fasten down every 3rd or 4th block just for the fact that if you ever get high winds, the vibration against the building could loosen some more blocks. By going every 3rd or 4th block, you are tying the building to the slab.
theoldwizard1
SE MI
Thank you very much. I'll have to look into it more and definitely put up a drain or do gutters. The water is just a pool at the drip line.
DEFINITELY need a French Drain !
Late winter/early spring is the worst time. You can frequently get standing water sitting on top of frozen ground. Then it will re-freeze at night.
Only a French Drain will move that water away BEFORE it can freeze solid.
Holzarbeiter
This with some mods
Use a Simpson Strong Tie HTT4 or equivalent at the door rough framing, the nail flange should be attached to the king stud. if the half block at the door is hollow, drill an oversize hole for the allthread and use an epoxy adhesive capsule from hilti or simpson and guide it into the hole drilled in the slab with tube or equivalent, install allthread, let cure before torquing nut. Make sure not to drill through slab. similar repair to the left at loose full block
