Speeds and feeds depends on other things than just referring to the material as "metal." Aluminum will cut much easier than say, stainless steel. Using quality drills and blades makes a big difference. Many drill presses have step pulleys on the motor and spindle to change the speed. Often there is a chart explaining what speed each combination will attain. You can do a Google search for what RPM to drill a hole in whatever particular material you are drilling. Some band saws have the step pulleys too. TPI and the grade of the sawblade is critical for cutting steel. Also, can be searched on Google.
Hope this is a start to help.
