one9gt's idea is the best if you can remove the grill.
If you can't you can use an old tooth brush and a vacuum.
Turn on the vacuum, put it near the dirt, and use the tooth brush to loosen the dirt so it gets sucked up in the vacuum.
If the tooth brush does not get it all out, you can use a toothpick to loosen the dirt if your careful.
Jim
