Ok, It has been a while since I have been on here as I have been basically working 7 days a week on my mothers home trying to get everything situated for her. This is an overwhelming, monumental feat for me as I am not a plumber,contractor, heating and air guy, but so far with you guys providing help I have been able to complete everything I have attempted so far.
The latest issue I am having is a galvanized MAIN water supply line that is leaking and clogged terribly and the water company is basically REFUSING to fix the issue. Upon further investigation I learned that the latest mayor of our town embessled all the water project funds, was found guilty, convicted, and is now working for the water company to repay the money he stole
So here are the facts ..I have a new black line ran to the curb well shutoff at my property line. I only have 42 PSI there on a good day with terrible volume. I have handled my responsibility and now the rest is on the water company which is clearly not gonna be fixed anytime soon.
I replumbed the entire home with copper and new fixtures.
Now I need to start thinking of installing a water holding tank, and possibly a booster pump. I have a few questions, and if needed I will provide required info any of you request (i am sure you will need further info to calculate requirements)
My first question is, can i run the water line coming into my house into the top of a storage tank WITHOUT using a booster pump, and the output coming out of the bottom of the tank to the home and increase my water pressure and volume? If so, what size holding tank would get me into the 55-70lb water pressure I need and want?
The tank would be 8 feet under the bathroom, and not much further than 20 feet distance from the kitchen and the hose bib. All water lines are very close to each other as water was added at the time of the bathroom, and kitchen addition. (old country 1952 home)
Is there a math formula to at least figure out the actual pressure that would give me an idea of water pressure at the bottom spout of a given size water storage tank? Incoming city pressure NOT included. From there do I add the 42 PSI city pressure into the equation?
As always, you guys are always so helpful. I thank you all in advance and value your input.
