which welder
tikiboi13
SAN PEDRO
How is it going fellas? In the market to buy a welder. I want it for buliding car frames and mostly automotive things. My friends have given me ideas but want to hear what the u pros say. I can run 110 or 220 to my garage. Models, brands anything. Mig is what I am thinking. Thank u guys for your time and looking forward to the knowledge. Thnks again
nissan_crawler
Wichita, KS
Search, there are so many threads on this exact topic. The most general consensus is that an HH187 is the most bang for your buck. Toolking.com sells warrantied refurbs for a great price.
If you can run 220, do it. Forget about the 110 welders.
79pacecar
Wisconsin
I have a Miller, Millermatic 250 had it for about 12 -15 years & I love it, still works great never had a problem with it & plenty of power for what your looking for.. I think the replacement model is a Millermatic 252
I like Miller welders the best, but I could be accused of bias as I live in Oshkosh, WI
trackwelder
n.y
Well it sounds like you will be doing quite a bit of work with it. The miller 212 would be a better choice over the 187. I have three mm200 that are over 20 years old each and would never part with any of them.
pipehack
chicago
I have a Lincoln 180c... I love it. Stick with a 220v unit. You won't build any car frames with a 110 unit no matter what anyone says. Go to www.weldingweb.com ... There are a lot of guys on here over there too.
CamarosRus
Renton, WA (Seattle)
I Bought a Miller 180amp "Auto-Start" (220V) based on good things Ive read on other forums. Bought from Air-Gas one of the biggest Miller Distributors.
Miller may still have the $50.00 rebate deal going also................
rsanter
visalia ca
a MIG is the best overall chpice for welding most stuff.
if you think you are going to need to do aluminum then you can go with a TIG
bob
metal1313
clinton NJ
i like the hh187 alot, but also a miller 252 and 212. but they both cost a ton more than the hh187. if your just learning and arent going to be using the welder daily i dont think you can go wrong with the 187
back2class
110 are good machines for hobby use but sounds like in your place a 220 would be better. My local home depot is clearing its old stock of welders out. They have the Linclon 175 for $299 right now. I think it may be missing the gun though.
back2class
110 are good machines for hobby use but sounds like in your place a 220 would be better. My local home depot is clearing its old stock of welders out. They have the Linclon 175 for $299 right now. I think it may be missing the gun though. I am running a Linclon 140 right now but if I felt like I needed a 220 I would have jumped on it. I have also owned hobart and it was a nicer rig if you ask me.
speed bump
Butte Montana
Lincoln powermig 255 or 215
Miller Millermatice 252 or 212
Easb Migmaster 210 or 250
All of the above will be more than adequate for just about everything you could want to do. Personally I think its mostly just what can you get the deal on and whats easiest to get consumables for.
nissan_crawler
Wichita, KS
First off, how much money do you want to spend, and how often will you be doing it?
I won't argue that the 250 series aren't nicer, but it's a big jump up in price compared to the hh187 class, depending on what you need to do.
sberry
Brethren, Michigan
For auto work the 180-200 class machines work well, all of the major brands. If I was on the cheap the 187 would be hard to beat, very, very good arc. I would really consider real need before I geared up to do alum due to the cost but HH210 or MM211 which has a side benefit of being able to run on 120V.
Electric demands are low for this class of machine as well as being somewhat portable and compact. The 215-212 or larger are great, the 212 still runs from 30A service, good where extended use and 30# or larger spools are needed, 250 class for working on equipment.
I have all of them but find myself reaching for 180 machine about 90% of the time. The low end works great on light sheet with the smaller wires (good for automotive) and we run 030 in them though to give them a bit more poop. The 180 class run good from extension cords.
pipehack
chicago
STAY VERY FAR away from the Home Depot models........ I have a good friend that is a rep. for Lincoln (which is why I get good deals) They are junk.. mostly plastic **** inside and the voltage is tapped and not continuous. You might want to look into HTP also... They cost more than the Red and Blue ones but I heard great things about their customer service. Miller welders have an awesome website. not here to argue with you guys. Just thought I would give you a heads up on the Home Depot models.
sberry
Brethren, Michigan
As for INTERNET welding, I have nothing against welding web but a couple of the best forums are Hobart and Miller, also ITW is a poster child for running companies, both those have the best tech support and service in the industry and would likely compete with the best in that dept with anyone.
sberry
Brethren, Michigan
The 210 is spool gun ready, I rank it about 10% better than my old Linc SPT right at the top end. Both machines work up to 1/4, I give a little edge to the Hobart but on 3/16 or under they just smoke with 030.
I ran the machine about 2 inches before this plate from the door chart then said, ok, lets see what it will do. Can turn it up hot enough that it just melts right in with very little operator input.
sberry
Brethren, Michigan
Here is a start/stop with about a volt difference, up a little reduce the splatter and make it easier. A pre-clean to the plates would also improve things a little.
84TurboBuick
Illinois
Damn those are some nice looking welds!! :bowdown:
Oh how I wish I had a better welder!!
T
tikiboi13
SAN PEDRO
Spent the night wiring up the garage with 220 outlets on 3 walls, now the fun part of buying. Been looking on the net for prices. Today is the day. Thanks to everyone for their ideas and opinions
sberry
Brethren, Michigan
This is one of those things where the quality of the machine really makes a difference. The competition for who is "best" is intense and very competitive. The cost difference between a POS and a decent machine is relatively marginal and the potential for payback and lots of use is big. If it works good a guy is tempted to really use it instead of becoming a 400$ dust collector. A small garage often has one machine, one gas, one wire and these units are really tuned around the nature of this work. Its a thing that is reliable, seen lots of them run years in grueling environments with no issues, if you wonder if its you or the machine,,, its you. Home garage could never wear out a 187.
sberry
Brethren, Michigan
Hobart HH210 on cart. A couple verts to show how much heat the machine will put into the piece and the last one was a project we build with it.
sberry
Brethren, Michigan
Just more stuff.
speed bump
Butte Montana
After running a Snapon MM250SL made by HTP I would buy a Hobart before I bought an HTP mig welder. 1/3 the cost, the consumables are cheap and it will weld better to boot.
zr52002
I have a millermatic 211. Paid $950 brand new at Airgas about 3 weeks ago for it. It is a beast. It is missing a few features of the 212, but for just over half the price, I just couldn't go for the bigger machine.
sberry
Brethren, Michigan
The Home Depot machines are fine, they change the model numbers for that market. As for tap vs continuous, I prefer taps, like them way better and most hobby types will see better results from the ease of setting. Easy to repeat. My little Linc, 3 settings, thin, med and thick.
A couple older models were missing a couple gears, I think the HH180 had a 4 speed but the newer ones are right on.
I will agree about the machines from the tool trucks, no reason to pay double or 3 x for a ******* when the proven brand is at hand. As for HTP, by all reliable accounts their regular machines are fine and they have pretty fair support but again, the marginal price difference makes it a wash.
Jarred Hodges
I have a millermatic 175 and it works great. It will do anything I want although the heaviest thing I will work on is a pickup truck
sberry
Brethren, Michigan
Pictures from file. I work with the apprentice.
kartracer55
Tough call, I would say Hobart is the best bang for your buck if your not going to be using it "daily"
That being said, Our Miller Dynasty machine has kicked *** at school.
paranoid56
San Diego, Ca
lol, thats a lot of misinformation. you can build a car frame with a 110v unit
what do you build frames out of? 1/4" steel? LOL there has been many frames build with a simple 110v mig welders.
i myself would go with TIG. i love mine :D
vssjim
McLean Va.
I have been very happy with my Lincoln Power Mig 255 I bought from Indiana Oxygen free shipping to boot at that time anyway.
JD6619A
we have the Powermig 255 XT at work good unit. Used a buddies millermatic 252 veryn nice machine as well. I'll be looking into a HH 210 this fall for at home
pipehack
chicago
You're right
35mastr
Norcal
I also have the Miller 210. Have had it for quite a few years and has done very well.
Check out www.cyberweld.com They have some good deals and free shipping.
I buy alot from them.
35mastr
Norcal
Just because it has been done. Does not means its right. You can also use JB weld but would you?
I like my TIG too.
