Older Baldor, switch going horizontal is a tip off. If it startup I would buy it, this era are the best made, real Hp amperage, heavy cast parts. As to actual model, take Ohm reading of coils, note capacitor specs, some parts are marked with part numbers, research Baldor manuals. If you lucky you may have a diagram in the motor mount.
Is $70 a smoking deal, warm deal, or the going rate? I'll have 3 hours in the car, I don't want to drive 3 hours for an OK deal.
He said he thinks it's 6".
Are 7" wheels easy to get? Are they expensive? I'll likely get one grinding wheel and one brush? How much do they cost, does the missing wheels make it a bad deal?
Thanks. I told him I'll take it, now I just have to find a time to go get it, and I hope the price doesn't go up, now that he knows the make and model.I would go buy it. Especially with gas being so cheap. But $70 is a great price!
If you need a little more info, check out the thread of the restoration I recently did (in progress) on an 8" Baldor of the same era.
http://www.garagejournal.com/forum/showthread.php?t=321420
7" wheels are hard to find locally, but a plethora of them are available online. Try Enco, they list them by specific sizes and dimensions.
I read through your thread a few days ago. Great write up. How much do you have into your rebuild, in case this one needs it?
I got the grinder for $65. It's missing one of the arbor flanges on one side. Is there something special about these flanges, that I would need to find a Baldor one, or can I find one the same size and just use it?I kinda went all out, replacing and refurbishing everything.... I probably have less than $100 in to it.
Realistically, if you are not missing anything, and there are no DAMAGED components, say $20 for the bearings, and $10 to give it a nice prime/paint. Plus some extra for new stones/wire wheel.
The rest is just time and labor. Stripping the paint, polishing the shaft, pressing the bearings, etc. Makes for a real good project.
Mine still isnt done, waiting for some parts back from a machinist, and then i have to source tool rests.
Thanks for all the info. I'm thinking I'll paint it hammered light blue to match my Wilton vise.![]()
All I can find on Enco is 7" wheels with 1"bore. Can I adapt them to 5/8" with a bushing, or do I need to find 7"x1"x5/8" wheels?
"Still need to press the bearings off. Any trick, or just press them off?"
Nothing special, I use a mix of a little grease plus telfon powder . Someone changed the bearing on this, the originals were open bearings. As suggested, change the capacitor, capacitance needs to be close but not exact, as long as the replacement is a run cap. You have a true 1/2 hp grinder. Trickier to get the replacement on, bearings have a tendency to "jump" while pressing, I did not do it but you might warm the new bearing before pressing, not hot, say 140 F . Motor interior looks far less used then mine was.
Highly recommend SKF Energy Efficient bearings (low friction seals), more expensive but motors run cooler, smoother, tested them myself.....
http://www.ebay.com/sch/i.html?_odk...kw=skf+bearing+energy+efficient+6203&_sacat=0
