A quick case study on rustoleum floor kits
the_cowman
IL
Back in 2009, I'd just bought a home and knowing I'd be doing a lot of dirty work in it and not wanting to stain up the concrete and hurt resale value I decided epoxy was the way to go. At the time the only option I knew of was the rustoleum kits that I've since read time and again are terrible wastes of money that one should never install.
Well I just ran across pictures of that installation taken just after it had cured and thought I'd post them for the general consumption of the internet...
So how did it hold up? Well the only place where any of it ever came up/chipped was a small spot where I had a forked tractor loader sitting on the ground and put it in gear before raising the bucket... scratched some of the coating off at that spot. There were also a few rust stains where metal items sat in moisture.
Here's a picture taken in 2014, 5 years later and showing how the floor was generally treated. All types of oils, gas, diesel, dirt, road salt, dropped tools, etc... I was definitely not nice to it.
A good cleaning with degreaser and a pressure washer and it looks just about as good as new.... wish I'd taken a picture before we moved but it really does still look good. The easy cleanup was probably the best benefit of it IMO.
So, there's a case study for you. Did I just get lucky? I prepped the **** out out of that floor, probably hit it 4 times with the pressure washer, etched it twice, let it dry for days, and ran a vaccum cleaner over it to get any dust before installation.
Well now I live at a new house, and I'm building a new workshop and contemplating what product I might want to use on the floor.... every source I have online including hear is screaming that rustoleum is junk... yet I had this good experience with it and it's significantly less expensive. As I price things out I'm probably spending at least 2x more on the more premium products and seriously wondering why I should spend the money when I had a previously good experience with the cheap stuff.
frank001
Southern California
I used Rustoleum Epoxy my new garage one year ago and have had zero problems. Still looks great.
http://www.garagejournal.com/forum/showthread.php?t=284998&highlight=frank001
SunsetsAndFriends
the_cowman - sounds like you are happy with the Rustoleum epoxy at your last place. Did you use the solvent based product they call Rustoleum Professional?
I suspect that if you compared the cost of Rustoleum to modern professional grade products that you would spend as much or more using Rustoleum, if you applied the Rustoleum product at the same thickness as the modern professional grade products.
*Also, a true professional/industrial grade epoxy is going to be more durable and last longer.
*There are other reasons, including speciality products that fulfill specific site or installation issues. For example, if quick turnaround or low installtion temperatures is a key factor, then choosing a product like Legacy Industrial Nohr-S might be an option.
*Also, keep in mind that Rustoleum Professional is in the 69% solids by volume, meaning 30% thinner coating per gallon as compared with 100% solids epoxy.
Hivolts
Okay, okay. This thread is us accepting it looked good when you left. We need those pics too. To each their own. Prep is definitely the key though. It's like buying a Toyota Avalon when a Lexus is available for more cost.
brownsmustang
SWMO
I had a similar experience with the rustoleum epoxy. It held up amazingly well and I only had one area that came up but it was a drip of paint stripper that took it up. I used the garage in a similar fashion as you and simple green and a mop made it look like new. Are there better products out there, yes I'm certain there are. Is rustoleum worth it for the average garage? Imo yes.
Sent from my SM-N910V using Tapatalk
OldNeons
Midwest
We have not used it as hard as you have, but our Rustoleum professional epoxy is looking great after several years. No complaints, would use it again!
EWT
I used it on a previous house and it was still almost entirely intact after 12 years. It didn't make for a "pretty" floor with a huge amount of depth and gloss, but it wasn't damaged by contact with automotive chemicals or impact from dropped tools and the like and it didn't lift. I was more than pleased with it given the cost.
red
Hudson Valley, NY
Just remember that the product you used years ago most likely isn't the same product that you'd buy today. This from EPA mandates or manufacturing product changes.
frank001
Southern California
